Question about Maxtor OneTouch III 500GB 7200RPM USB 2.0 External w/16MB Buffer Retail ****... 500 GB Hard Drive
Hi, My maxtor hard drive is not working anymore. Every time I connect it to a USB port on a laptop/desktop I continually hear a clicking sound and nothing happens. It does not show up in "My Computer". It is probably about 6 years old and only recently has this problem appeared. I have some old data I would like to retrieve off this and copy to another backup. Any help would be greatly appreciated. Kind Regards Richard
    Sergeant:
  • 174 Answers
The symtem which you explined is confirm that the HDD is deffective but still you can replace the USB cable. check the supply is proper or connector if external supply is their.
you can aproch data recovery centers which are available in your area
data recovery software is available, that also you can try
I hope your problem will solve
let me inform
Posted on Apr 07, 2011
Maxtor basics 500GB external hard drive not working
Every time you turn your computer on it is going to "spin up" and the light is going to come on. Just because the light goes out and it idles so that you can't hear it anymore doesn't mean it isn't still on. It is. You can verify this by using windows explorer to view it and its files.
Jun 29, 2012 | Maxtor BASICS Personal Storage 3200...
My WD element desktop was working properly but now when i connect to my laptop it is not recognizing not even on the bottom left corner of the desktop even sound is not there when connecting. My harddrive...
First things first. When you plug the drive in and power it on....does the drive spin up? If so, if you place your ear near the drive, you should hear a whirring sound of the drive platter spinning and the slight clicks of the drive arm moving.
If you don't hear this, it could be a power problem with the drive or the drive itself may be done.
If you hear the drive spinning, then most likely your data is safe. From there I would suggest trying to plug the drive into another USB port on your laptop, or even into another computer altogether. If it works there, then you most likely are having a driver issue, or perhaps a drive letter conflict.
(For instruction on how to resolve a drive letter conflict, see my response to this post: http://www.fixya.com/support/t8601787-need_driver_8gb_sandisk_cruzer)
Otherwise check the device manager in the control panel to see if you show a "USB Mass Storage Device" show up under your USB device drivers in the list. You may want to right click and uninstall it if you do see it.
If you DON'T hear the drive spinning, I would check the power first. Make sure it's receiving power (look for indicator lights etc) you might be able to remove the drive from the plastic enclosure and use a USB Drive adapter (Like one of these ) to recover data from your drive
(http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770)
If the drive is not spinning and the power or drive adapter doesn't work, you may have a bad hard drive.
Good Luck
Mar 08, 2011 | Western Digital WD Elements Desktop...
My Maxtor One Touch 3 (300gb) external hard drive is not being recognized by my computer (or my laptop). I plug it in to the back usb port, turn the Maxtor on, then the light turns on, but the computer is...
Hi Jane,
If you are using Windows as an operation system, you can try to install the HDD manually
Click on the Start button
Right click on My Computer
click on properties at the bottom
look for the Hardware tab and click on it
look for the Device Manager button and click
look for Action in the top menu
then scan for new hardware
If this does not work, look on the Device Manager screen and you will see + Disk Drives
click on the + and it will list the drives that it sees
if you see the external HDD uninstall it and reboot
Hope this helps
Dec 22, 2010 | Computers & Internet
My maxtor external hardive is connected and the light is on, the laptop recognizes it (makes that sound when u put in a usb) but no autoplay comes up and when i look for it when i click "my computer" its...
make sure that you plugged in the external HD to a USB 2.0 port. if you are using a desktop. try to plug in at the back of your tower. if you have available usb cable, change it
Mar 26, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't open Maxtor one touch 4 mini
If the external hard disks is plugged to a USB port and is not detected anymore, try uninstalling the USB Root Hub devices in the device manager. They will automatically be reinstalled on reboot and that can help fix detection issues.
But did you look in the Disk Management module of Windows to see if the disk is there? Right-click My Computer and select Manage.
Jan 05, 2010 | Maxtor OneTouch II external hard drive...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor 3200 300 gig. Drive is not recognized via
reboot the laptop, reseat the cables, and try connecting the drive to different usb port. if that still doesn't work, most likely the drive has gone bad.
Oct 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
My maxtor 200GB drive is not recognized by my CPU anymore!
Hi Crkinard.. i think you shuld first find out whether the problem is with the external device or your computer... so check if the device is recognised by another system... as you have been using the device dor couple of years i think yours computer's drive for external devices should have been corupted.. so check out the device with some other computer.. if it is recognised in that computert then you can easily reinstalled the software for your device again..
Oct 13, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
MAXTOR OneTouch III mini edition 100GB
does the hard drive spin up? is there any ticking / grinding sounds from the hard drive? are you plugging it into a different usb port than you were before?
May 01, 2008 | Maxtor Hard Drive
Maxtor OneTouch III 500GB 7200RPM USB 2.0 External w/16MB Buffer Retail ****... 500 GB Hard Drive Logo
69 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
