Question about Sonance Sonamp 1230 12-Channel Amplifier
No audio output from Sonance 1230 but it does pass the analog signal throught to second 1230 that does work
Digital audio output tv
Digital audio refers to technology that records, stores, and reproduces sound by encoding an audio signal in digital form instead of analog form. Sound is passed through an analog-to-digital converter (ADC), and pulse-code modulation is typically used to encode it as adigital signal. A digital-to-analog converter performs the reverse process, and converts the digital signal back into an audible sound. Digital audio systems may include compression, storage, processing and transmission components. Conversion to a digital format allows convenient manipulation, storage, transmission and retrieval of an audio signal.
Oct 13, 2013 | Insignia 42" LCD Flat-Panel HDTV
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
Can not get sound playing a vcr tape but can get sound playing a dvd please help
What connections are you using for the DVD and VCR output for both the video and audio?
If you are using a "digital" signal (such as optical audio/HDMI/etc) the VCR audio will not pass through these outputs. You will need to connect up the analog (red/white) RCA connectors on the back of your unit to hear the VCR audio
I hope this help, Magoo
Mar 06, 2011 | Toshiba DVR670 Player
How do hook a nintendo to a tv
The first step is to check what types of outputs provides your Nintendo, the most common is video composite and stereo outputs (yellow, red and white RCA jacks), the second sted is tochek if your TV has the same type inputs, then you must have the cable (with 3 RCA plugs at both sides), these are analog signals, if your TV has only digital input signals (HDMI) and your Nintendo doesn't, you'll have to get a converter from analog to digital video and audio.
Feb 12, 2011 | Televison & Video
Hello ! I'm not sure how to connect my kef psw 2500 sub to my yamaha amp. I've got a subwoofer out on my amp but there's 4 inputs on the sub and I don't no which one to use ! Please help as getting...
Just for clarity, I need to explain what the four inputs are on the KEF subwoofer. There is a left and right RCA input which is the input signal to the subwoofer and there is a left and right RCA output which is the High Pass output from the subwoofer.
On the back of the Yamaha receiver, you said you have a subwoofer output. This output is most likely the mono subwoofer part of the home theater system and can be used if you like. The left right signal input into the KEF is summed into mono so if you only connect one channel you will basically reduce the signal level by 1/2 (-3dB) but it will work fine.
Alternatively, if your Yamaha receiver has monitor out and monitor in, you can run the monitor output signals to the subwoofer and you can then run the high pass outputs from the subwoofer back to the monitor in. This will give you the subwoofer and provide a smoother signal matching with your audio system.
It is not always easy to connect the subwoofer up to an integrated receiver/home cinema system using the high pass channels of the subwoofer as you don't always have access to the analog output and input of the front channels. In this case, just use the Subwoofer output or just the monitor out only.
I hope this solution is helpful.
Dec 03, 2010 | KEF Audio PSW 2500 Subwoofer
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
No audio from analog audio outputs on denon 988
When you use VCR or DVR out, you must also turn on the VCR/Video 2 Tape Monitor function on the front input select, then it will pass audio. IF you need further help, post a comment and I can pull the specs on your receiver and help some more. Hope this helps.
Aug 23, 2009 | Audio Players & Recorders
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
Digital audio out jack
That output only works with digital signals (digital tv channels and digital audio from the hdmi in jack).
The HDLCD2600 has no analog out. Sorry.
Aug 14, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sonance Sonamp 1230 12-Channel Amplifier Logo
61 people viewed this question
Top Sonance Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ASTEREY ELECTRONIC...
Level 1 Expert
Are you a Sonance Audio Player and Recorder Expert? Answer questions, earn points and help others
