Question about AEG Washing Machines
My Lavamat 52435 has started to stain clothes, leaving brown/black marks which won't wash out. Perhaps it's dirty where I can't see - the inside where I can see is clean. What should I do? Is there a simple solution? Mike Lunan
Washer_tech
  • 164 Answers
SOURCE: brown stripe marks on clothing
you don't say what brand or model you have. basic answer would be either a transmission (leaking) or a seal problem
Posted on Nov 11, 2007
SearsTechToo
  • 261 Answers
SOURCE: WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Posted on Oct 06, 2008
  • 4 Answers
SOURCE: Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
Posted on May 11, 2009
canbruce75
  • 1776 Answers
SOURCE: leaving dirty marks on clothing
What kind of washer is it? Most of the time spots are caused by a reaction between a detergent and a fabric softener. Try hand washing a spotted garment in warm soapy water. If the spot comes off, they were caused by fabric softener/detergent interaction.
A common problem with older GE/Hotpoint washers was that they would let transmission oil leak back into the tub. (Which is why I asked what kind of washer it was.) Sure hope this helps you find a resolution to your problem. Best wishes.
Posted on Jul 23, 2009
  • 311 Answers
SOURCE: Washer leaves brown stains on clothing, looks like
The only oil would come from your rear bearing assy. Its a very expensive repair. I know the units not that old but I wouldnt waste a service call on it unless they are giving free estimates (which most co.s are not). Its gonna need the rear bearing and back half of the tub. Low end estimate will probably well over half the cost of the unit. Hope this helps _MJ_
Posted on Mar 10, 2010
Testimonial: "Thanks, that is what I figured after looking on line. "
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Brown stains on clothes after taking out of drier (removable on hot wash)
Could be rust, is your laundry kinda damp?
Has someone dried a pair if brown or black shoes?
Check the conditions inside the drum.
Use a solvent to remove any dark marks.
Sand away any rust and paint over with high temp paint.
Sep 16, 2011 | Dryers
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
The rubber on the inside front of the washer ("the door boot") gets very dirty, slimy and is all stained. As I pulled the rubber back to clean it, it was digusting ! It is starting to leave marks on the...
at this point and time the best thing to do is replace the door seal.and then make sure after each wash cycle you dry out or leave the door open somewhat in order to help keep it dry and clean
Jan 27, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer leaves black marks on my clothes. I do not use fabric softners
Do you mean Black, really black marks? Perhaps dark brown.
Some marks comes from moldy seals, other marks comes from leaking gears from the machine. Examine the marks, check if those marks are oily or not.
Nov 27, 2009 | Fisher Paykel EcoSmart GWL15
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
