Question about Craftsman Garden
@hotmail.com I have a snow blower attachment mod#842.240530 and need 4 parts. skid shoe #3045, scrapper #12659, lift assy #786, Spacer #11285. my email bjkolr@hotmail.com Please give me costs and directions to order.
4 Suggested Answers
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
  • 81 Answers
SOURCE: have an older tractor and snow blower attachment.
Go to sears.com and lookup in the parts listings for the tractors model number and the snowblowers model number and they will show all the attachments and brackets needed to run it. Hope This Helps Don
Posted on Dec 02, 2009
SOURCE: Bolens model 3012H lawn tractor attachment install instructions
I don't know the answer to this question but I wouldn't mind getting one of those tillers for my tractor. If you ever decide to part with it let me know! j e s s e m e r s o n @ m y m a c m a i l dot com
Posted on Aug 12, 2011
Have a gravel driveway bought a Ariens 24 Snow Thro adjusted skid shoes to lift machine, is the scraper blade also adjustable, it is throwing a lot of rocks?
Yes, they are all adjustable. Loosen the hardware, Find something to use as a shim... a few paint can stirrers.. put them under the Scraper to lift it about 3/8" then tighten the hardware. See how that helps the stone throwing. Gravel driveways are tough for Blowers and Plows...It's best to actually leave snow on the driveway to pack down and form a Base. Then the next snow will be stone free.
Jan 07, 2017 | Garden
TORO snow blower
Get ur self a can of Wd 40 and fluid film and saterurate the the skid and bolts for a few day period icly checking and continue spray the rust will eventually loosen up and u will be able to move the skid.. The initial loosing of bolt my be a bit hard to break just take ur time.. Another option is to cut the bolt with grinder or hack saw and replace it.. Good Luck
Oct 26, 2016 | Garden
Mtd model 31a140000. Why doesn't throw snow like it was?
Do you rev it up when you use it? they are made to rev up. Are the paddles that throws snow worn? Even if the skid plate is worn but the snow is getting to the paddles it should throw snow. In saying that no snow blower will throw good if you do not have much snow. The more the better it should throw. They won't work well if there is under 3 to 4 inches. and really throw well.
Jan 19, 2016 | Garden
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
Need to decrease Wheel Speed. Blower works well except for this. Keeps plugging up, because it moves to fast.
part of the drive plate. Lift the machine up on it's auger and take the bottom cover off. with the speed lever at its slowest see if the little friction wheel moving linkage can be adjusted so the friction wheel gets as close to the middle of the drive plate as possible. Sometimes it's just an adjustment on the shifter arm.
http://www.ereplacementparts.com/poulan-pp11530es-96192001901-snow-thrower-parts-c-16962_168114_294540.html?page=4
loosen and adjust item 20 and 25
Dec 14, 2015 | Garden
How do I reverse blower motor on bobcat sb 240 snow blower attachment
if your skid steer doesnt have a reversing remote valve (contact bobcat some models can be retofitted in field), then the only way to reverse is to unhook the hoses from and to the drive motor and unscrew lines to put hoses reverse direction , becarefull there maybe some residual oil pressure still there if you really need to do this after reconnection to skidsteer and remote is activated then blower will run backwards
Feb 21, 2015 | Garden
How to change blower on 2002 Lincoln t/c
Before blaming the blower, find a wire running from the blower to a small electric part that sticks out of the Firewall or ductwork under the hood. This part, a Blower motor Resistor is notorious for failure.
It has a single electric wire plug and 2 bolts securing it in place. Sometimes tapping it with a broom handle or snow scrapper will reactivate it until the next time. Aside from any Warranty on a new part, you pretty much can have the problem again with a new part.
Oct 01, 2014 | 2002 Lincoln Town Car
My toro snow blower runs good but it does spins
It sounds like the auger is not spinning. I recommend you look up your model at www.arcolawn.com and check that the parts look like the drawings. Check your belt, idler pulley and auger assy.
It is a simple system and won't take more than two hours to replace the bad parts.
good luck
Joe
Jan 31, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
How to connect hydrolic lift to the 214 tractor from a 37a snow blower
Part of the blower when new and first installed was a
1) pivot bar
2) lift link from blower to pivot
3) lift link from pivot to center of the tractor
the pivot was to be installed on a pre-made bracket on the frame just inside the front grille. A hole in the front part of the frame allowed the longer lift link to attach to that bar and go to the center of the tractor. Those two pieces remain on the tractor as permanent, and the lift link from the blower to the pivot bar to be removed or installed as you intend to use the blower. If you have purchased the blower used, the original tractor it was installed on still has those pieces on it. Your local Deere dealer can provide the pieces if needed.
Dec 05, 2009 | John Deere Garden
Will a snowblower attachment model number 842-240743 fit on my riding mower
i have a snow blower attachment mod# 842.240530 sears and a sears 18 hp tractor mod # 917.258492 with no instructions on how to install them together? i dont know where all the parts go.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
208 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
