Question about Hydrofarm Flco95w Grow Light System
Okay, I have read here and on other website that the ICN-2P32-N can be used with 2 bulbs and I bulb. I have the diagram for 2 bulbs, but how do you hook it up to one bulb? DO I have an extra wire? Or do I combine the wires?
2 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: I bought 2 ICN-2P32-N for
Here's the wiring diagram for each ballast with two lamps.
ICN-2P32-N @ 120V
Posted on Jan 30, 2011
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
I have a 2002 Cadillac DTS. The right headlight is out when the ignition is on. However, it will come on when I unlock the car with the remote! But not if the car is running when I click the remote. A
Each headlight lens assembly has two bulbs - did you check both? These bulbs are used independently in different ways depending on the commanded tasks [e.g. unlocking car, car running during daytime with running lights (if equipped), headlights on (auto or manual - low or high beam)].
If both bulbs check out, I would replace them one at a time anyway just to be sure. It is not uncommon for a bulb to show a good resistance reading with a multimeter and then go open under full load. Also verify the bulbs and the wiring harness connector are seating properly.
Dec 05, 2014 | 2002 Cadillac DeVille DTS
I have 3 new t5 4 bulb ho high bay fixtures with an advance ICN-4S54-90C-2LS-G ballast. When I turn on the switch only the 2 outside bulbs light up on all 3 fixtures. How can I make the inside bulbs
If only two bulbs are lighting on ALL the fixtures, this usually indicates wiring.
Check wiring diagram as follows.
If unsure, contact local electrician to ensure proper wiring within your states electrical code.
http://www.stanion.com/pdf/advance4.pdf
Nov 24, 2014 | Home
How can I replace the light bulb that shows the odometer reading in a 1997 BMW 328i?
Okay here it goes. Disconnect the battery to avoid setting off the airbag. Lower the steering wheel. On top of the cluster is a couple of smal screws that need to be removed. Use a smal scew driver to pry the cluster enough to tilt it out. In the lower area behide the reading is a twist out bulb that you will have to get from the dealer. Now is a good time to change them all. The bulbs are pretty cheap even from the dealer.
Good luck
Sep 21, 2011 | 1997 BMW 328
I am trying to replace the fuse that controls the left dash lights. Do you know which one it is?
Well for starters there is one fuse that controls all the dash lights. So you might have a burnout bulb under the dash. Check the fuses but I'm telling you now it's a bulb
Oct 06, 2010 | 2000 Ford Focus
1988 pathfinder no dash lights no revers lights no tail lights no gaiges
If they all stopped working at the same time then it is probably a fuse or possibly 2. Check your fuse panels in the dash and under the hood. The dash lights and gauges should be a fuse labeled instrument cluster or guages, it is probably blown. The other fuse to look for will be the tail light fuse. This is where I would begin.
Sep 23, 2010 | 1988 Nissan Pathfinder
My right side brake light is out I've changed bulbs fuse is good still not working
MAKE SURE YOU ARE USING THE RIGHT BULB.IF BULB OKAY THE BULB SOCKET CORRODED OR LOOSE WIRE CONNECTION AT BULB SOCKET.
Jun 19, 2010 | 1998 Dodge Durango
2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
Fog/Driving Light Bulb Size: 880
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 558
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168
Dome Light Bulb Size: 562
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
Thank you for using fixya.
Apr 30, 2010 | 2000 Pontiac Montana
2003 Silhoutte, both lower brakes lights do not work. Bulbs or turn signal switch? Turn signals work okay. Cyclops works okay, fuses look good.
Bulbs are bad, most bulbs burn out around the same time withing a day or two and both of your brake lights may have gone bad. Try with the simple and inspect the bulb and replace if you see any discoloration to the glass on the bulb. Good luck and than you for using Fixya.
Mar 06, 2010 | 2003 Oldsmobile Silhouette
Hydrofarm Flco95w Grow Light System Logo
81 people viewed this question
Top Hydrofarm Garden Experts
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Angelo Monroe
Angelo Monroe
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
