Question about Cuisinart DCC-2000
Coffeemaker getting hot but not brewing
Hi, I just need help figuring out if the problem with my coffee maker can be fixed or if I need to get a new one. About 2 weeks ago we turned it to brew and the light came on and the inner plate got hot, but the brew process never started. The next day it worked just fine, the next day same problem. There is no rhyme or reason to when it will draw up the water and when it won't. We usually make the full 12 cups. Could I be overfilling it or does this sound like the machine is just fried?
Thanks!
  • 7 more comments
  • Anonymous Aug 19, 2008
    Unit will light up but nothing happens. Same problem just 8 months old. 3 year warrenty on new one but why can't they make a better product than this at the cost of $ 100.
  • Anonymous Aug 23, 2008
    Turn coffee pot on It brews whenever it feels like it.They all seem to do that! My father and aunt have one to. Does the same thing. Don't buy one
  • lkroberts58 Aug 24, 2008
    Same problem! Have "decalcified" (it worked then) and then has not worked consistently since. Very frustrating. Having trouble finding a Cuisinart service center to try to get it fixed!
  • Anonymous Dec 24, 2008
    I just recieved my 4th one under warrantee shipped to me and it has the same issue. Must be a huge problem!
  • Anonymous Mar 28, 2009
    We have the same problem, light comes on, plate is hot, but no brewing! Need my Java and not wanting to pay for Starbucks!
  • jimandangieb Apr 04, 2009
    Yes... Same problem here. The light comes on but it won't brew unless it feels like it. It seems to be possessed. Some times it sits there for an hour before it starts brewing.. I am back to using my trusty 8 year old Braun
  • Anonymous Apr 06, 2009
    DC2000 that heats but does not brew -
  • Anonymous Apr 30, 2009
    my problem is identical
  • Anonymous May 20, 2009
    I have the exact same issue with this coffee maker.. It works very well when it does work but its little brain seems to get scrambled and I have to let it set 12+ hours unplugged before the pot will start working again..
  • 8,596 Answers
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
Well, I called Cuisinart and she said to try decalsifying again. To put vinegar to the 4 cup mark and fill rest with water and let it sit for one hour and then try again, turning on the coffee maker. More info later.
Posted on Apr 03, 2009
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Feb 27, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
The coffee is not hot. I have PSTX series.
Does the bottom surface that the carafe sits on get hot. Too hot to touch? If not there may be a wiring problem. If it is a new machine, I would return it for another. Hope this helps.
Dec 25, 2014 | Mr. Coffee 12-Cup Programmable Coffeemaker
Coffeemaker shuts off in the auto brew cycle
Your Cuisinart coffee maker probably is defective, though new.
Jan 10, 2018 | Cuisinart Chw-12 Coffee Plus 12-cup...
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    I have the grind and brew thermal coffeemaker. The water does not get hot enough for steam to come off of the coffee when it is poured.
    Hi, I have owned that coffee maker for years.
    After it brews coffee, it does not have a warmer to keep it hot. It has a thermally insulated carafe. Such as regular lunchbox thermos jugs have. The reasoning behind this is that coffee heated after it is brewed spoils in a short time. (Of course, unheated coffee gets cold).
    What that translates to for you with regard to no steam is this. As soon as the coffee maker finishes brewing your coffee, open the top of the carafe, stick in a spoon and stir it.Then pour it. (I learned the stirring part working in a restaurant).
    If you have to wait before you drink it, do the same. Stir it first.
    Hope this has been helpful
    Love that grinder!
    Best Regards,
    Mark
    Jan 04, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
    We have a CBC-1600 10 cup coffeemaker. after brewing the coffeemaker beeps and turns off. The hot plate part of the coffeemaker will not stay on for longer than 5 minutes.
    The CBC-1600 is designed differently than you might expect. The stainless steel, insulated carafe is designed to keep the coffee hot instead of a hot plate keeping a glass carafe hot. Some people like that style better (including me). Some people - like my dad - don't think it keeps the coffee hot enough.
    Your coffee maker is working exactly as designed. The carafe itself is designed to keep the coffee at the same temperature as it was brewed.
    Dec 24, 2009 | Cuisinart Coffee Makers & Espresso...
    I've lost my manual for the Oster coffee maker model 3314-33 and the red "Clean" button keeps flashing after the coffee has brewed. Where can I download a manual so I can figure out how to fix this...
    Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
    Aug 15, 2009 | Oster HDX23 12-Cup Coffee Maker
    Need help using my coffee maker
    Thank you for note I went on Cusinart site and found a copy of the manual and got my coffeemaker to work.
    Dec 25, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
    I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
    When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
    The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
    Hope this will help you.
    /Mirran
    Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
    Coffee Makers & Espresso Machines Logo
    512 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    880runner
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
