Question about Frigidaire Refrigerators
My frigidare frc150ff is leaking. what is the matter with it
    President:
  • 2,187 Answers
The leak may be from the condensation of water. Check the panel at the back of the unit inside it. See if there is ice buildup inside. Remove all ice including the panel. It would be best to clean the unit while doing so. The leak may be from drain being clogged from debris or drain frozen which prevents water to follow the correct path.
Posted on Apr 07, 2011
My frigidare 241968503 is leaking water around where you plug the filter in?
Took out filter, placed forefinger firmly over one outlet and sucked, with my mouth on the other. heard seeping noise and found clear casing cracked very slightly where it is melded with the white front plate. This is a much simpler check before you start getting out your tools! Solution, replace filter and cross your fingers that this stuff made in Singapore will hold up for a few more months.
Mar 06, 2012 | Frigidaire Refrigerators
I have a Frigidaire FRC150FF fridge, the fridge light comes on but the fridge is warm. The frezzer compartment is working fine
How old is the fridge? Can you hear it running?
It could me many things. Could be anything from a dead compressor to a coolant leak.
Did someone change thermostat setting, maybe during a cleaning? There's a knob in the refrigerator section somewhere; see if it's turned to "Off" or to a less-than-cold setting.
If you hear the motor running, but it doesn't get cold, it probably doesn't have any refrigerant to compress. That could be recharged, but modern refrigerators are pretty tight, so that would also indicate a leak. With a leak, it will need recharging again sometime later.
Jul 22, 2011 | Refrigerators
There is a pool of water at the bottom of our frigidare dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Dec 29, 2010 | Frigidaire Dishwashers
Frigidare air conditioner thru wall unit Model FAH146Q2T2 leaking water inside?
Always make sure that your unit is tipped back towards the outside os it does not leak inside...
heatman101
Jun 02, 2010 | Heating & Cooling
Will a water valve for a frigidare refrigerator work on a kenmore refrigerator? the one shown for my kenmore won't work, but the one for the frigidare looks like it will work.
Actually kenmore don't make their own appliances, if you have been given a Frigidaire valve as a replacement for your Kenmore the likely hood is your refrigerator was made by Frigidaire. So the answer to the question is maybe. The second answer to this question is that all valves will most likely work on all refrigerators since they all work off 120v it's just a matter of adapting the water lines. Mike
Nov 30, 2009 | Kenmore Refrigerators
My frigidaire frc150ff fridge will not get cold
Completely defrost the fridge freezer, over 24 hours and switch back on, most times it will work properly again as this may need to be done on a yearly basis.
Sep 15, 2009 | Frigidaire Refrigerators
Icemakers,frigidare, gallery series
read the menual book and try again or replace it.
Jul 18, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water not entering freezing tray on frigidare side
Try replacing the washer in the solenoid valve. Sometimes it leaks by enough to freeze in the dispensing tube.
Feb 23, 2009 | Kenmore 53642 / 53644 Side by Side...
Water leaking from bottom of frigidare washer
You really don't have to take a panel off, depending on your washer model. All you would have to do, is flip the washer over on its side and check underneath.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Refrigerators Logo
189 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
