HDMI connection shows no video, but picture shows when COAX cable is connected.
  • 8,457 Answers
That HDMI connection hub might have shorted out and already dead.Tries tv unplug,replug it back in like about an hour later.For the tv to do a resetting itself back to the factory setting.Try using that HDMI connection hub again might work or not.Try other HDMI hubs for new connections for better chances for the tv to work with HDMI hubs connections again.
Posted on Apr 07, 2011
I have no signal,what can I check?
OK Joan,, I might need more info. not getting signal could be caused from several things.. one make sure the Dish Antenna is mounted correctly, (level, and true, [one degree off on earth is like 700 miles off at the Satellite.]) check you cables and make sure they is now wire touching the center core of the coax. if the coax has splitters, connections etc outside check for the corrosion inside the threads.
make sure the coax coming into the house is connected to the right place on back of the 222k. make sure u are on the right Video stream for the HDMI. are u getting any picture showing the Dish set up or is the screen all Blue.. if it is blue try to use the remote that came with ur TV (RCA, Vizio, Phillips,,,,etc) and look for the input, source , or Antenna button and push it to match your HDMI input..
Oct 28, 2014 | DISH Network Vip 222k Hdtv Satellite...
Panasonic DMR - HW100ebk.......... with both coax
So you have looped the coaxial through the Panasonic to the TV and have a HDMI from the Panasonic to the TV, right. When you turn on the DMR select the appropriate HDMI connection with the TV remote and you will be OK.
Oct 11, 2013 | Televison & Video
TH-50PX77U inputs
Many times a computer's post screens will not show up a TV set, and once the computer itself has loaded the drivers and settings, the set may need to be shut off and turned back on for the HDNI or PC signal to be detected.
It is also possible the settings you selected for display properties cannot be displayed on the TV.
As far as the component video signal, are the connections correct? Sometimes people mistake the composite red, white and yellow for the composite system that divides the red, blue and green video signals.
While also possible, but rare- there may be poorly soldered connections on the "A&D" board (logic board) .
Jul 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
Connection to TV by HDMI cable
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
Mar 06, 2009 | DISH Network DVR-625 DTV Receiver /...
Cable box HDMI connection probelm
This is from the Yamaha user guide:
The analog component video signals (with 480i (NTSC)/576i
(PAL) of resolution only) are converted to the S-video or
composite video signals and output at the VIDEO or S VIDEO
MONITOR OUT jacks.
The question is what kind of signals you get from your HD cable box.
Jul 06, 2008 | Yamaha RX-V1800
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
No Picture
sounds like the digital video controller went out. you can test this on this unit by using the coax out and connecting to your tv, it seems to have its own video card looking inside the unit, however it is possible it is controlled centrally thorugh the main card in that case you will confirm by it not working and still only gettting sound through the coax.
Feb 21, 2007 | Samsung DVD-R135
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
