Question about Sony Cyber-shot DSC-W55 Digital Camera
Memory Stick Error
When turning on my 4.1 Cybershot camera, error reads, "Memory Stick error". This is an office camera. After checking memory sticks from other office cameras, same message appears, so I don't think its memory stick, but camera damage. Books suggests if memory stick is not damaged, then terminal section of "memory stick" is dirty. HOw would I clean that?
  • 10,594 Answers
Take wet cotton swab of alchohol and clean the terminals of memory stick.
Posted on Aug 06, 2008
Clean with a pencil eraser
Posted on Aug 17, 2008
  • 489 Answers
Hi
Lets clear something up first... If your camera is 4.1 MP, then it's NOT a DSC-W55 and this post seems to be in the DSC-W55 category. Knowing the actual camera model would really help in this case!
If you have a slightly older camera, it will NOT say "Memory Stick Pro" on or near the battery door or where the memory card slot is. If you camera does NOT say "Memory Stick Pro" you CANNOT use PRO cards, you must use cards that are 256MB or less and do not say "PRO" on them.
I'm fairly certain this is the problem you are having. Good luck.
Darntoothysam com
Thomas
Posted on Oct 10, 2008
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Format error on my sony cybershot dsc-s730
Format error comes because memory stick has an error. Please format memory stick by going in to Menu>> format>>OK
If error still comes then memory stick is bad and need to be replaced with new one.
Apr 09, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
When i turn on my camera ,memory stick formatting error comes up
If it is Sony DSC-T200 camera then use maximum 2GB memory stick as it can not handle 4GB memory.
Feb 25, 2009 | Sony Cybershot DSC-T200 Digital Camera
Sony Cybershot p72 Memory Stick Error 1301
Switch on your your camera with the memory card in it, goto menu and format it. The problem will be solved.
Jan 04, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Format Error in Sony Cybershot
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Sony Cyber-shot  DSC-W55 Digital Camera Logo
118 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
