Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Need to lock my connection - Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
    Problem Solver:
  • 5 Answers
need to lock my connection - moz-screenshot.png Protecting your network with WPA/WPA2 security
Setup steps:
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless
6. Use the drop-down menu and select "WPA/WPneed to lock my connection - wireless_secur_wpa.jpgpan>
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will need to lock my connection - wireless_secur_wpa_auth.jpge automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obneed to lock my connection - wireless_secur_wpa_key.jpgou to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Posted on Apr 07, 2011
WL80T65CW1. Why is it displaying fault 234 and will not cycle?
Replace just the lid lock assembly to start with and see how it goes. Lids are quite expensive and don't usually need replacing. You can always get a lid later if you still have problems.
Aug 25, 2015 | Fisher and Paykel Aquasmart wl80t65c
The left rear door lock on my 2008 Impala LT will not lock and unlock with the remote control. All others work ok. Can only operate left read lock manually.
Hello: The lock/unlock unit is part of the mechanical door lock assembly. The first thing to do is remove the door panel. Check and make sure the linkages are all connected, then make sure the wires are properly connected to the door lock assembly. If all the previous is ok then you will need to replace the lock/unlock assembly. to do this you need to remove the mechanical lock assembly first then remove the actuator. It might be best to have a professional accomplish this task. You also should disconnect the actuator an check to make sure you have 12v going to the actuator when you activate the door lock switch.
Jan 14, 2011 | 2008 Chevrolet Impala
My car locks work on 3 doors, but one of the locks have to be locked manullay
which ever door it is need to remove the door panel to check linkage connection[clip may have popped off or broke ] or the lock actuator may need repair or replacement[test connection to lock actuator for power if no power test wiring if power actuator may need replacement]but most likely its the $2 clip which most auto stores carry
Jun 22, 2010 | 2002 Mini Cooper
Problem with Central door lock on peugot 106
there is a switch attached to the back of the door lock that opens all doors, it may have fallen off or become damaged, or the mechanical connection to the lock may have snapped.
if the door itself does not even open with the key on its own, the lock mechanism has become detached from the locking rods inside the door, you would need to take off the door panel and look / feel inside near the lock, there is a thin rod connected to the actual locking part and the part the key is inserted into, as well as the internal lever to open or lock the car, it may have popped off. The key-lock itself is usually held on by a thin flat round circlip-washer affair, this may have slipped out too and the key-lock is not connected any more.
Oct 24, 2009 | Peugeot 405 Cars & Trucks
Doors not unlocking properly
This could be due to the connecting rod between the key lock barrel and the lock mechanisim (in the door, connected lock button, breaking. The connector comprises of 5 parts, a rod, a spring, ans two 'plates' at either end. The spare parts can be bought from autmobile shop for around 10 GBP
Sep 14, 2009 | 1993 Toyota Corolla
1999 Mirage central locking installation
constant 12v found at ignition switch or fuse box you need a test light or multimeter
Aug 01, 2009 | 1999 Mitsubishi Mirage
Vw jetta 1996 GL.my door lock came off from door handle when ...
door locks are operated by a round solonoid make sure it is connected with a wire .. this is what locks and unlocks your doors when you push the button .. thanks Jerry holler if you need more.
Feb 05, 2009 | 1996 Volkswagen Jetta
Need unlocking code of Samsung SCH- w339
hi i am using rel connection can i buy sch-w339 and use the phone for rel connection with unlocking code given by u
Dec 31, 2008 | Cell Phones
IPOD DISABLE EVEN IN ITUNES NEED HELP!!!
put the ipod into restore mode, hold the power button down and the menu button for 20 seconds,then when you see the screen changed to the ipod usb,connect it to your itunes
Oct 23, 2008 | Apple iPod touch
IPOD NANO
you first have to find out if it's a screen lock (you can succesfully connect it to your computer) or a "manage lock" (connecting doesn't work too)
if it's a screen lock, connect the ipod the the computer you first used it with (the one you used to install the ipod), open itunes and then disconnect again, it should be unlocked
if it's a manage lock, connect the ipod to the computer and restore the factory settings, warning, this will erase ALL data.
then reconnect it and synchronise
Dec 02, 2007 | Apple iPod nano
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
103 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
