Question about Acer Aspire One PC Notebook
Acer aspire one running ubuntu 10.4, does a good job, using 1gb ram. But screen periodically greys out to black and white and freezes for a short period of time - less than one min. Ideas on what is going on please
  • 81 Answers
With Ubuntu 10.4, 1GB will run it, but sometimes it will need a bit more, so consider putting in another 1GB stick. With 2GB it's almost flawless.
Other than that... the reason it seems that the screen greys out is because the OS is not responding well to the driver for the video in the laptop. I would look up the drivers for it, and see if there is an updated version that Ubuntu might take.
In my opinion, it might be a combination of the two things I stated above. The blacking out might occur due to the driver, but the length of time might be affected by the RAM.
Posted on Apr 07, 2011
Laptop freezes when working
could be to much running at the same time,
try doing a disc cleanup and a defrg.
Apr 19, 2014 | Acer Aspire 4730-4947 Notebook
Acer Aspire AM3470G-UW10P desktop- I purchased 4 of these and cannot install windows 7 on them
If your computer is 6 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7 http://windows.microsoft.com/en-AU/windows7/products/system-requirements
Feb 08, 2013 | Acer Refurbished Black Aspire...
Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Sep 26, 2012 | Acer Aspire 9300 Notebook
Aspire one ao533 will not operate with a 2gb memory
Acer have to have the following memory installed
Single-channel DDR3 SDRAM support with one soDIMM module
Can take up to 2 GB of DDR3 system memory
Also the bois has to be the very latest version for it to work
Apr 05, 2012 | Computers & Internet
Need abetter graphic card for acer aspire 5251
in Acer Aspire Series is using Intergrated Graphic Card.
that mean if you wanna Upgrade your Graphic Resolution,
you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
But in My Computer Properties the RAM will Show only 1Gb.
Because another 1Gb of RAM you've use for VGA.
you can check it from dxdiag.
(for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
Jan 07, 2012 | Acer Computers & Internet
Hi, I have a little problem with the RAM of my Acer Aspire 8600. Probably I am using a wrong RAM module for the upgrade, but I would like to have your opinion. I have instantiated a new module of RAM...
Probably you have used the wrong RAM module in the upgrading. You must be using 1 GB PC2100 RAM instead of PC3200 in order to have a complete 1 GB of RAM.
Nov 09, 2010 | Acer Aspire 8600 PC Desktop
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
Black screen
No. Don't order motherboard now... try changing RAM. Similar problems are because of faulty RAM only. And it won't cost you more to replace the RAM. Its very certain you will get rid of this problem by this only.
Apr 23, 2009 | Acer Aspire 5672WLMi Notebook
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
Upgrading Acer Aspire T180
Try putting back the old RAM.
If it does not happen anymore, then it means it was the RAM.
This does not mean that the new CorsairRAM is necessarily faulty, but that it is having compatibility problems with one of the other devices, for example the video adapter.
Nov 04, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
