Question about Garden
Hi, the fault code A7 keeps coming up on my KEW 1640h power washer, it cuts out after 30 seconds of pressing the trigger.
2 Suggested Answers
  • 211 Answers
SOURCE: chainsaw cuts out a few seconds running
hi frado
check the fuel lines,make adjustment to the carb,set the T ,check the fuel filter.Inside the carb,at the fuel pump side there is a screen,carefully clean it.Hope theese help.
regards savumihai71
Posted on Dec 01, 2008
Xtreme pressure washer keeps cutting out.
If it is a gas powered machine and it cuts out when you release the spray gun trigger, it means that your unloader valve is stuck closed.
It would help to have more information about your machine and your problem. Gas or electric? Does it start up and run fine or cut out a few seconds after starting? Does it cut out when you release the trigger?
Does it cut out while spraying?
May 07, 2014 | Garden
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
I have a Kew Hobby 80. The output from the lance is not constant but pulsates.
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Feb 22, 2010 | Karcher PSI Electric Pressure Washer
Pressure washer keeps cutting out
Carb problems: needle seat is sticking!
Dec 08, 2009 | Garden
F11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Found this presure washer in the basement and want to know if it works the motor runs when you plug it in but does not build press. The brand is kew hobby
This may be as simple as still having air in the system.  Connect the machine to the water supply (but not the electric) then squeeze the trigger and allow water to flow for at least 60 seconds.  During that process, hold the nozzle outlet under the surface of water in a bucket so you can see when air stops coming out.  Keep going until you're sure there's no more air in the system.  Then switch it on.  If it still does not come up to pressure you'd probably be wise to abandon it.
Apr 16, 2009 | Garden
DYSON washine machine fault
To Clear F11 Code after a power cut.
3, Power on
Sep 05, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
