Printer does not print , all cables connected
    Sergeant:
  • 174 Answers
Make sure the interface cable is good or change,
check the ink level of cartridge
re install the printer driver
Posted on Apr 07, 2011
My mp610 no longer prints email documents, but will still print satisfactory colour pictures (Photos). Both black cartridges have been replaced with new. Could this be software or a printer fault?
this is software problem! you did not state what operating system you use this museum quality printer, as my telepathic powers somehow vane... anyway they work only in hollywood flicks... just generic advise:
open any office document and try to print - if it did not, or print garbage - but still print photos - definitely software problem, which can be exacerbated by printer connection or interface
suggesting hot water - IT PRINT PHOTOS! this meant that this is not physical printhead problem but SOFTWARE INTERFACE! pls do not listen to airheads...
now, procedure:
1. remove all cables from the printer including cable connecting to the computer
2. reconnect all cables to the printer except computer
3. try print any photo - printed? printer is ok, maybe cable - interface or computer itself...
4. while computer is on, and printer is on - connect computer to the printer via usb cable (even if you have it on wireless! disable it for the moment), did computer detected it? can you print test page? if yes and yes - you just solved the problem and computer rectified it
if not:
1. disable wireless (if present) and disconnect physical cable from computer
2. uninstall drivers pertaining to the printer
3. go to http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp610#DriversAndSoftware
and download drivers correct for your printer and operating system (remember the bit which you did not tell on the beginning?)
4. after download - start installation, when prompted, connect usb cable to the printer and the computer
5. print test page - printed correctly? solved the problem... if not, then error will be on ingress port of the printer, or cable or egress port of your computer, you cannot eliminate error on the printer but:
change the cable and change the port on the computer to that which you know is working, for example port where your mouse is connected.
if still no joy - use this printer as local for your photos and buy cheap laser with very, very cheap laser cartridges...
hope this will help you to solve your problem do not forget to vote...
Jan 10, 2015 | Canon Pixma Mp610 Photo All-In-One Inkjet...
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
The printer is not printing any document
Hi
Please check
1. Do you have a printer cable failure?
The printer will not be printing if its not connected to the computer. Check that the printer cable connecting your printer to the computer is firmly attached at both ends. Apart from this cable, there should be one more cable which is the one connecting to the wall outlet.
2. In case it still not work after checking try resetting and printing.
3. Else please change the Data Cable if it is very old one.
Jul 22, 2010 | HP LaserJet 1300 Printer
Printer connected but not printing
If your printer has a network port you should be using the network adapter.
Otherwise you want to make sure you connect the printer with a USB cable to the appropriate port on the D-Link.
Once the USB cable is connected you should be able to add the printer from your computer as a shared printer.
You will not normally see any activity lights on your router for the USB connection because it does not send or receive information the same way the LAN cables will.
I do recommend a LAN cable though as it works much better with routers. If your printer does not have one I would look into getting a network printer.
Thanks,
Pat
May 12, 2010 | D-Link DP 300U (DP-300U) Print Server
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
I have reconnected my HP PSC 1315 to my printer, however, I cannot get the printer to work. Can you please help me? The printer will not do anything. I have received a print test after I installed the...
Hi melovesjags:
Try these steps.
Does the product
print from the
computer?
Connect the parallel
cable or USB cable to the
product and the
computer. Use a wordprocessing
application to
send a print job to the
printer.
The cable is not
connected correctly.
Reconnect the cable.
An incorrect printer driver
is selected.
Select the correct printer driver.
Other devices are
connected to the parallel
or USB port.
Disconnect the other devices and try again
to print.
There is an LPT port
driver problem.
Reset the computer port settings. See your
computer user guide for instructions.
The formatter has failed. Replace the formatter.
Hope these help
Jul 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
Print jobs no longer arrive on printer
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
Aug 18, 2008 | Lexmark N4000e Print Server
11 people viewed this question
k24674
jasbo
jasbo
