Question about Echo 3 TE SL7 3 New Electric Scooter by Shoprider
I need a new on and off switch - Echo 3 TE SL7 3 New Electric Scooter by Shoprider
  • 692 Answers
Keith go out and buy a on/off toggle swith and replace your current switch with the toggle switch about $6.00 or less and all you have to do is connect the two wires off the old switch to the toggle Hope this helps
Posted on Apr 07, 2011
  • drivercourte Aug 21, 2011
    Lennieg, I have the same issue with our scooter. What on/off toggle switch do you suggest. The throttle also acts as a variable gas peddel so I am not so sure your suggestion will work.
Brake lights wont turn off unless i remove fuse, does that mean i need a new fuse or??
no --you do not need a new fuse
you probably need a new brake light switch or need to have the switch properly adjusted
Feb 17, 2016 | Hyundai Cars & Trucks
How to fix power switch?
you need the following tools
soldering iron, solder, grounding strap ground the unit and you.
soldering plunger to remove old solder, the right switch, buy a new switch, solder,
disassembly the unit, find the broken switch unsolder, clean contact area, solder new switch, with out over heating the board or new switch, reassembly, test, your done
Oct 02, 2015 | Tablets & eReaders
Driver fvront window not going up goes down fine but not up.changed power window motor still the same whats wrong?
Probably needs new switch. Might try spraying wd-40 into switch, but not sure how these newer ones are made.
Jun 12, 2015 | 2010 Dodge Avenger
Switch stopzilla to new labtop
You can't switch it from one to the other, you need to install it onto your new computer, if you are paying for something on the stopzilla, you will need to enter your registration information into the new software. As to getting rid of it on your old computer just uninstall it.
Feb 22, 2014 | Dell wireless Laptop/labtop Notebook...
Need to know how to program new ignition switch & cylinder
At you year make and model the factory alarm was just the pellet that disabled starter,the alarm was part of the ignition switch if anything you will need to replace the aftermarket alarm. A repair will cost you more than to replace the unit,You will have to cancel the aftermarket alarm under the dash and restore the ignition wire that is spliced for the alarm relay.
Mar 25, 2012 | Cars & Trucks
I have power running to a 2 switch gangbox. Each
As long as the power is running from the breaker panel to the switches rather than the fixtures then it should be pretty simple.
1. Run a new 2 conductor wire from the existing box to the new box at the top of the stair.
2. Install a switch at the top of the stairs.
3. Disconnect the hot wire that is running to the two existing switches and connect it to one of the two conductors running to the top of the stairs.
4. Connect the remaining conductor on the wire going to the top of the stairs to the two existing switches.
Note that if you want to be able to use the Dimmer function from the top of the stairs this will be much more complicated. You will need to put two new switches at the top of the stairs, run more wire, the new switches will need to be 3 way dimmers and the existing switches will almost certainly need to be replaced as well. The wiring will also be much more complicated.
Jan 09, 2010 | Lutron Claro Screwless 2 Gang Wall Plate...
Need wiring diagram for switch.......
try looking at this site .http://www.toolpartsdirect.com/cgi-bin/partbrands.cgi
Mar 16, 2009 | Drills
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Sep 08, 2007 | Ovens
Echo 3 TE SL7 3 New Electric Scooter by Shoprider Logo
Top Echo Health & Beauty Experts
Robin Hill
Robin Hill
Bill Boyd
Jeff Tilburn
Jeff Tilburn
Are you an Echo Health and Beauty Expert? Answer questions, earn points and help others
