Question about Iomega Prestige 1 TB USB 20 Hard Drive
Why does a new 1TB hard drive , (1000 gb) only show up as 932gb in properties. if there is a .94mb program that makes the hard drive work what happend to all the other 67gb .6mb. whith the price of machine thats a lot of gb and storage space not accounted for
    Guru:
  • 509 Answers
The discrepancy is from the partition formatting. In order for the computer to organize the info, it has to have a defined pattern of blocks to use, like a file cabinet system. The partition definition takes a little space to lay down on the drive, also not all of the drive may be usable due to the partition blocks being laid down may not fit exactly in the available space, so the remaining space is ignored. Like trying to use a circle to draw a square onto. there are parts of the circle you just cannot include in the square. The file system and allocation table operates within the partition.
In most hard drives it comes out to about 9% of the total space.
Posted on Apr 07, 2011
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Dec 11, 2014 | Samsung Computers & Internet
Toshiba 1tb hdd external hard drive not reading
Try using HDD Regenerator to check and possibly to repair the disk. HDD Regenerator allows to repair bad sectors on damaged hard disk drives without losses of the existing data. http://ulozto.sk/xzjZ2Bd/hdd-regenerator-1-71-keygen-h33t-murtajiz-zip
Jan 11, 2013 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Hitachi Deskstar causes a Power Error on my Gigabyte GA-Z68AP-D3
test all leads that attach to your hard drive including electrical extensions, SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
make sure the CPU central processing unit has thermal grease and a dust free secure seating
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
could be a memory dump you might have to many programs running at one time putting to much stress on the CPU not having enough ram will do this
might be getting to hot make sure the CPU has a dust free secure seating and has THERMAL paste
if you right click in the bottom toolbar select task manager applications you will see whats running also processes you will see whats ticking over if you see something running that should not be select end now you might even uninstall that program and some unnecessary programs
check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope it helps
May 08, 2012 | Hitachi Deskstar 35 1TB 7200RPM SATA II...
My WD 1TB hard disk drive shows me loaded with 300GB capacity of folders but when they are not seen on my pc
1) Open any folder on your your computer and go to: Tools > Folder options > View tab > check "Show hidden files and folders" and uncheck "Hide protected operating system files". 2) Look at your hard disk again, if you still can't see any files on it, there must be an error of your disk. To solve it, go to: My Computer (or Win+E keyboard shortcut) > Right click on the drive representing the 1TB hard disk > Properties > Tools > Check Now... > Check both boxes to fix errors.
Mar 07, 2011 | Western Digital My Book Essential Edition...
How can i format 1TB Toshiba Canvio portable hard drive to FAT32
Right Click on your new drive in the Computer
Choose a File System (NTFS is ideal most cases) and give the new volume a name if you choose. You might like to call it something like "Portable Drive," or "Removeable Drive." If not, just take the defaults and click "OK."
You will get one last warning that you are about to format your drive and erase all data. Click OK to proceed. When you see the process has reached 100%, you are done and you're new external hard drive is ready to use!
Oct 28, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
My Iomega Home Media Network Hard Drive ("HMNHD") used to work perfectly, until I reset my Dell Inspiron 1545 and installed Windows 7 to upgrade it from Vista. I backed up all my files, program data,...
First and the foremost thing is that when u backup any info to an external hard drive try only back up the data that u have saved. Coz application cannot be saved if done they cannot be retrived. Now if those files are asking for permissions then right click on the file - properties - then on the securities - click on add - then Under Enter the object names to seclect type in Everyone then click on Check Name now Everyone will come in Underlined - click on OK - U will come back to properties tab then on top click Everyone - And under Permissions for everyone Under Full Control Check ALLOW - Then OK
this should fix the issue.
If this does not helps, since u have transfered all the data back to the PC why not format the External Hard Drive. Connect the Drive right click on it the see it teh format option is there or not if present then foprmat it.
Aug 01, 2010 | Iomega 1000 GB Network Hard Drive
Won't recognize drive
Have you checked the disk properties to see if the 400 GB of data is still showing. may be your data might be hidden foir some reason. can you give more details pls
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Seagate FreeAgent, 500 GB p/n 9nk2al-510 stopped working
There's not much troubelshooting you can do with a failed external disk. power off PC and hd and then disconnect all cables, wait 30 secs, power the PC on, let it boot to the OS, power the hard drive on and then connect. If the drive shows up but you still cannot access it or get weird property readings, it generally means the hd controller has failed. If the data's worth more than $1000, you can take it to a data recovery group like Ontrak or Cherry Systems, but otherwise, just get a new hd and restore whatever backups you have.
Oct 07, 2009 | Seagate Free Agent Go Small 12 GB USB...
Kingston 4gb
check virus with a updated virus cleaner.
Nov 22, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Iomega Prestige 1 TB USB 20 Hard Drive Logo
485 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
