Question about Dishwashers
Help, My CDA dishwasher WC130 will not run a full cycle it starts ok then runs for approx 30 secs then beeps as if itb has finished. I have cleaned rotor arms and filters checked for kinks in pipes.
SOURCE: she47c0 bosch dishwasher won't stop
You're hosed.  This is likely a bad control board module that can run you in excess of $200.  Even if you're within Warranty, Bosch will gouge you for labor, as that is NOT covered by warranty.  Top that with abysmal customer service and you're in for a world of hurt.  Sorry, but it's time for a new dishwasher. :(
Posted on Oct 28, 2008
  • 157 Answers
SOURCE: Dishwasher
Hello davidweavers, Does the motor run during the wash cycle? If yes the flow control valves have a problem. The valve to direct flow to the arms is not activing. #1 Close the water input, disconnect the AC power, and open the housing to aquire access to the internal water routing. Check the wiring connections to all componets by reseating the plugs. Physicaly check all valves by moving the arms, if one will not or is very hard to move this could be the problem. Remove the valve & soak in a 50/50 mix of vinegar over night. Test movement. If bad contact Mgfr. for replacement. #2 All valves move freely and all wiring connections check good you have an electrical control problem. Contact the Mgfr. for a control box replacement. When & if you contact Mgfr have the model & serial#s handy. #3 Please E-mail yours truly of results.
Posted on Nov 05, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
  • 942 Answers
SOURCE: My the dishwasher will not drain. The pipes are
Hi..
If your dishwasher will not draining you need to check this
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Good luck !!!
Regards
PCmania
Posted on Jul 13, 2009
SOURCE: when starting wash cycle the dishwasher cda cw447
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from www.espares.co.uk, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Posted on Sep 12, 2009
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
Cda wc140in
Hello, hope you can help? I brought a second hand (but brand new, but not used CDA wc140. Its plumbed in fine, switch on, the end light comes on, the programme button just beeps when pressed. There's no info in the manual. I hope I haven't brought a second hand dud, any ideas to start would be greatly appreciated. Steve...
Apr 24, 2012 | Dishwashers
CDA WC130 integrated dishwasher partly fills with water then pumps out and beeps as if the programme has been completed
Check the sensor of the liquid at the bottom of the dishwasher. Sometimes that is the cause of the fault.
Mar 13, 2012 | Dishwashers
Cda 350 dishwasher
I have a cda cw195/1 integrated dishwasher, the red light stays on and when I attempt to start it the cycle begins then stops and it continually beeps, all the filters are clean and there are no blockages any ideas
Jan 14, 2012 | Dishwashers
Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Jan 31, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
192 people viewed this question
Top Dishwashers Experts
Owen Barnes
