Question about Cell Phones
The touch screen just stoppped working, have done a hard reset now i cannot continue when it asks to tap for calibration.
    Sergeant:
  • 138 Answers
You neeed a new touch screen fitted
Posted on Apr 07, 2011
My Garmin nuvi 1390T will unlock the screen without entering all or part an incorrect password. It usually takes a while to pick up the satelite signal. The touchscreen needs to be more responsive to the...
Try performing a soft reset or a hard reset to the unit.
The soft reset is done by holding down the power button for at least 10 seconds and allowing the unit to power back on.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
The touch screen may need recalibration.
This can be done by pressing and holding the top left corner of the screen will powering on the unit.
Keep pressing the top left corner of the screen until the calibration screen appears.
Use a stylus or the round back part of a pen to press the dots to calibrate.
Once the calibration is done the unit will continue to boot up showing the Garmin screen.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 27, 2011 | Garmin nuvi 1390T Car GPS Receiver
My touch screen needs calibration
Hey
its simple just go to Menu > Settings > Phone Settings > Calibration
you'l be asked to tap on screen until the calibration settings are done.
Thanks.
May 03, 2011 | Samsung Star GT-S5233 Cell Phone
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
My touch screen doesn't work. i tried to calibrate it but it doesn't even go into calibration screen. please let me know how i can fix it. thank you
Since the touch screen is not working, what you have to do is to reset the device. To reset the device, turn it off and on to see if it does the job. If that does not do the job, then hold down the power off/on button for about 10 seconds, the device restarts, that way it should work, but if it does not still work, the only solution is for you to jeep calibrating the screen continuously till you get it done.
The proper process to calibrate your screen is for you to:
  1. Turn off your nuvi,
  2. press your finger on the upper left corner of the screen (that is before powering on),
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold on to the touch screen with your finger for about 30 seconds or more till the white calibration screen comes on(white screen with touch dot),
  5. Then follow the on screen information.
Try it several times till you get it to work. It does not just work the moment you try it, you have to try it over and over again.
Dec 24, 2010 | Garmin nuvi 205 GPS Receiver
I have a Garmin 885 the sceen does not work. touch keys do not work. I cannot get past the Garmin start up when plugged in . when I unplug it I get the warning page and select ok and get pge with wheree ti...
I recommend attempting a hard reset of your Garmin Nuvi 885.
Then I would upgrade the system software to the latest version. This often brings back unresponsive Nuvis.
Perform the Hard Reset
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  4. Press "yes" and the unit will reboot.
Upgrade the System Software
The upgrade software is a download available from Garmin. Installation steps are detailed here.
I hope that helps.
Dec 30, 2009 | Garmin Nuvi 660 GPS Receiver
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
Palm m505 problem after hard reset
ouch... Try opening it up and run a business card between the digitizer and the screen. Fixes m500s and m100s.
Apr 02, 2008 | Palm m505 Handheld
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
UNABLE TO CALIBRATE TOUCH SCREEN
The only possible fix is to try to clean the edges of the screen in case any particles are trapped between the screen and the case, this can confuse the touch screen.
Do this with a soft toothbrush, it will not damage the screen.
If that doesnt work then in all likelihood the screen is broken, it can be replaced but this is not trivial. There are guides on the internet on how do do this.
Dec 30, 2007 | Nintendo DS Console
Cant get out of screen alignment program
OK, Now anyone watching this forum can hear the truth. Well start with how to get out of the designator, however this will make the screen out of alignment by about 2mm. tap on the corner targets until you get to the center one. Try tapping off to the side top or bottom of the target further and further away until the program exits.
To fix the problem first try using the corner of a piece of paper and run it along underneath the plastic covering the edges of the touch screen. Use as much force as you can without creasing the paper. Do NOT press down on the touch screen!
Other than that the reason why you can't tap on the center of the last target is either a marked or damaged screen. Look at your screen carefully and identify any smears, marks or fingerprints. Clean these using a soft cleaning solution (such as for camera lenses etc.) and try the designator again. If this does not work look for scratches. If these are found in the area of the target then sorry, but you can never designate your PDA again.
Dec 08, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
