Question about Canon PIXMA MP130 All-In-One InkJet Printer
The printer shows repeatedly the following line: The waste ink absorber is almost full. See manual. Unfortunately I can not find any solution in the CD that came with the machine. Thank you for helping out.
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit.......Done.
I hope this help!
Posted on Jan 16, 2015
  • 310 Answers
Try this combination menu-scan-copy-scan and go to the service menu,then find something like reset ink absorber or reset purge count.I hope help you.
Posted on Apr 07, 2011
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
Everytime i print documents, the windows show THE INK ABSORBER IS ALMOST FULL CANCEL PRINTING ..pls help me to fix this problem ..thanks
So you probably have a Canon Pixma printer with an error code E27 = "Waste ink absorber full or platen waste ink absorber full".
These two tutorial videos will teach you:
1. How to clean the MAIN ink absorbers: http://www.youtube.com/watch?v=VVpjqBr7KjU&feature=fvwrel
But there's a second ink absorber - the PLATEN one - which he does not talk about. The PLATEN is in the black plastic directly underneath the printhead as it slides back and forth. CLEAN THE PLATEN TOO before following the Part 2 video to reset both the MAIN and PLATEN ink absorbers in your software. And don't repeat his mistake when putting the printer back together - the springs he points to at 4:30 WILL fall out! 2. How to reset your printer's internal firmware to remove error alert: http://www.youtube.com/watch?v=4IrBdw7el2E&feature=fvwrel
P.S. Of course it is much easier to bring it to ther printer service (even better if your warranty service can do it for free, if the full ink absorbers error was not caused by too intensive printing, i.e. not your fault).
Mar 06, 2011 | Office Equipment & Supplies
The ink absorber is full
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Waste Ink absorber is full.
this msg show that you will need to reset your printer waste ink counter and replace the waste ink pad.. you can try to reset it with a resetter software here.
http://www.fix-printer.moon4ever.com/?cat=5
May 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Screen shows picture of printer cartridge holder and message "waste ink absorber is almost full"
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
May 21, 2010 | Canon PIXMA iP90 Mobile Printer
Where is the waste ink tank?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error 8
Dear sir your problem is or E8 mean
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer does not print
If you own a Canon printer and are looking at this article, chances are you just got the "Waste ink absorber is full" error, or something similar, and have no idea what it is or what the printer expects you to do. Unfortunately, or fortunately, you are not the only one with this problem and there are ways to solve it. If you call Canon support, they will promptly tell you to bring the printer for servicing, that doesn't help, however, when you have a report or resumé to print by tomorrow.
Firstly, it might be important to note that the waste ink absorber is a little pad that sits under the cartridge's "home" position and collects any loose ink that may be on the cartridge. This prevents smudges, so it's a good thing to have. Many ink jet printers have them, but as far as I know, only Canon PIXMA printers display an error when a certain internal counter suggests that the ink absorber may be full. If you've done a lot of printing, the ink absorber may actually be full and you might need to have it cleaned or replaced to ensure the best printing quality. However, if you haven't printed that much or you have and you just need to print something right this minute, there is a way to reset the counter and stop the error from showing up again. Until the counter reaches a certain unknown point, that is, in which case you'll have to repeat the procedure.
Unfortunately, the instructions for resetting the counter differ from printer to printer and again, as far as I can tell, are not mentioned in the manual. People have been able to figure out how to do it, however, and there are instructions online for many printers. Searching for your printer model and either "ink absorber" or "used ink tank" should provide you with a few links to check out. Almost all of them are pretty easy to follow, albeit contrived and not easily discoverable on your own. Once the counter is reset, you should be able to print again.
If the ink absorber pad in your Canon is indeed full, you might want to replace it. Having it serviced is generally not a good option, since it will likely cost almost as much as the original cost of the printer and is not covered under warranty, since it's considered normal wear and tear and not a defect. Canon will, however, sell you a new ink absorber that shouldn't be too hard to replace. The number to call, in the United States, is 732-521-7230, which is their New Jersey parts center. They are open Monday through Friday, 9:00am to 8:00pm EST and should be able to sell you a replacement. You can also try to clean the ink absorber on your Canon without replacement using tissue to absorb as much ink from the absorber as you can.
Jul 16, 2009 | HP Photosmart C6280 Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
