Have just bought a 1HP chigo airconditioner and observed that the airconditioner always first default to 30 degrees and much later (in some cases hours) before moving to the preset temp on the remote control each time i activate the swing button on the remote. Is this how the equipment is designed to operate or a fault?
  • 3 Answers
This is not a fault
Posted on Apr 07, 2011
Hi.. Can u help me with the torque settings for the 2003 ford ranger TDI diesel cylinder head pls.
I looked in my data and I don't have that information but thought I would mention the last few times I bought cylinder head gaskets the tightening instructions were included.
These days we refer more to tightening instructions than to torque wrench data because the majority of engines are built by robots and they seem to have difficulty with setting and using a torque wrench and so they are programmed to tighten the bolts a certain number of degrees and so later we are condemned to doing the same.
Many manufacturers recommend always fitting new bolts and once everything is prepared and the bolt threads and washer faces are greased, they are installed and tightened to a low initial torque value of usually around 20 lbft. From that point each bolt is tightened in turn, usually in three or more stages by the amount specified.
For example one engine I am familiar with requires an initial torque of 18 lbft and then tightening 60 + 60 + 60 degrees with a further 30 - 60 degrees after warmup and cooling. The bolts are tightened in a spiral pattern from the centre outwards.
It is extremely important that each stage is completed without distraction as it is often disastrous to lose your place and tighten one bolt too much. It is best to make a plan and have an assistant observe you and to mark each bolt and each stage on the plan as it is completed.
May 17, 2017 | Ford Cars & Trucks
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby SilhouetteĀ® DWC276BLS Wine Cooler
Bought hitachi nr90ad nail gun and it isn't firing right..what exact size nails should i get ( as in 35,33,or 30 degree nails)
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
Jul 25, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
What do the symbols on the Chigo airconditioner remote stand for or mean?
i have a problem wit my ac, it runs for ten minutes and stop. I thought was a time set accidentally but its not. what can be a solution for this. it is very hot here, please help
Jun 28, 2011 | Heating & Cooling
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 27, 2011 | LG Heating & Cooling
Maytag window airconditioner, temperature setting changes automatically gradually from 73 to 88 degrees. Unplugged it, started it again, works for about 30 minutes fine, then changes temperature again.
You have the sleep mode set, which gradually increases the temperature setting( Usually 1degree each half hour until the off time is reached), so turn off sleep mode and it should be fine
Apr 19, 2010 | Heating & Cooling
Battery drainage
20 to 30 shots on "fresh" batteries! Do you use the flash on all shots. That really drains them. I would try to set the camera to "factory default settings" in case you changed something that is causing a drain. I hope you just bought some bad batteries.
The best thing I EVER bought for my Olympus was the Re-chargeable Lithium Ion batteries. The worst thing I did was buy an off brand. That was a waste. I ended up getting the more expensive brand Olympus recommended and all was GREAT again!! 1,000's of pictures later and they still work great.
Good Luck
Oct 03, 2009 | Olympus SP-550 UZ Digital Camera
GE airconditioner. Temperature setting goes up to 86 degrees by itself. Nothing can change it tried evrtything
Sounds like the stat is "defaulting" to factory setting, or, what are the programmed settings at? A programmable thermostat will revert to programmed settings unless placed in "hold". If all ok, time to get a new stat.
Aug 23, 2009 | Heating & Cooling
Haier air conditioner
the 5 degree tilt is a recommendation so that the drain pan would not get flooded. Just make sure the outsied part of the airconditioner is lower or tilted.
May 18, 2009 | Heating & Cooling
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
