Question about Radio Communications
I have a Uniden UH013. I have recently started having problems with the channel selector. I have managed to fix this, however I can't seem to scan chanels. The scan button will allow me to switch between OS and GS modes but won't let me scan the channels. Has anyone had this problem before and how did they fix it?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
If squelch is halfway up and you push "Scan" it should go. But if that doesn't do it, it may have fried. Take to repair or buy new one..Sorry.
Posted on Apr 08, 2011
I recently purchased a Uniden bc345crs scanner. I programed 5 codes, but it will only scan one of the codes continuously. What do I need to do to have it scan the other programs? Thanks
Make sure you do have frequencys stored. Turn it on, push button to clock, then press bitton to scanner, then press hold, then the channel # you want it in, press hold again, now press e, enter frequency, press e again, if you want more channels press up, press e. Do this until channels are full or what you want. Then press scan if radio is ok it should scan.
Jan 24, 2015 | Uniden Radio Communications
Tv stuck one channel
Be sure tv is set to antenna and not cable . Do auto scan . Find this in setup menu. If this does not work check the mfc website for software update. replace the main board as last resort.
May 29, 2013 | NEC Televison & Video
Hi, I have a Uniden CB UH013, All works OK other then very low volume when receiving. Checked all connections and internal and external speakers are low volume. People receive quite clearly. The radio was...
There is a small capacitor that drops value next to the audio output ic, usually heat sinked to the inner chassis, " ic should be checked" for hairline crack and performance, to answer your question it can be repaired.
Apr 29, 2012 | Uniden Radio Communications
I don't have the manual for my Uniden Bearcat BC 855 scanner.
You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 30, 2009 | Uniden BC248CLT Base Scanner
Channel selector switch for the UH 011 Uniden
Call uniden 1.800.297.1023
You can order the part through them.
Dec 04, 2009 | Radio Communications
Handheld scanner/preprogramed frequencies
You sure confused me . . .
My recently purchased BCD396XT came with a mind of its own - not matter what I did, it would only scan the preprogrammed systems in Alaska. That didn't do much for me here in Texas, so I had to beat the thing into submission. First I installed BuTel programming software, then I deleted ALL the factory programming. Finally, I used the software to download and program what I wanted from the database at www.RadioReference.com. The scanner does exactly what I want it to.
Jun 11, 2009 | Uniden BCD396T Handheld Scanner
Just bought this scanner used and having problems with Banks 3 and 4
while the scanner is scanning press buttons 3 and 4 and they should start scanning too, if they dont then go to the first channel in bank 3 manually and press LO to unlock it, then hit manual again to go to the next channel and press LO again to unlock it( all of the channels in the bank are probably either locked out or empty(nothing programmed into them)
Sep 05, 2008 | Uniden BC80XLT Handheld Scanner
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Turn off power, hold down the 2, 9 & L/O buttons while turning the power back on.
Aug 09, 2008 | Uniden BC60XLT Handheld Scanner
Uniden UBC92xlt
foursons, have you tried resetting the scanner yet. On pg 47 it mentions about turning banks of channels on or off. Possibly some banks got turned off. Resetting the scanner starts on Page 53.
I hope this helps somehow, and good luck with it,, Mechanic
Feb 11, 2008 | Uniden BC92XLT Handheld Scanner
Uniden BC248CLT BASE SCANNER
If it seems to be locking on a channel like someone is talking but no sound, it's possible that the speaker quit working. Simply plug in an external speaker into the plugin on the back. I have a BC 860 that the speaker recently quit. That's what I did and it sounds better. Good luck Mechanic
Jan 14, 2008 | Uniden BC248CLT Base Scanner
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
