Question about Whirlpool Washing Machines
I can not open the door on a whirlpool front loader duet HT 085sc/wg. It is flashing dL F. I have pressed cancel, unplugged and plugged back in later. It will not do anything on any setting. Not turn on not let the door release. Help I need the clothes that are in there..... Oh and they never washed, they are just stuck.
  • john_cross Apr 07, 2011
    I've posted this as 'clarification' rather than 'solution' to leave your posting 'live' in case some else can come up with a better solution!
    'dl F' stands for Door Lock fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Sorry but a service engineer's attention is required ;-0(
    Good luck,
    John C
    Sergeant:
    Champion:
  • 202 Answers
Hi... sounds like your drain pump is bad...
Posted on Apr 07, 2011
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
MY WHIRLPOOL FRONT LOADER WASHER JUST QUIT WORKING. IT HAS LOST ALL POWER. THE DOOR WILL NOT EVEN OPEN. PLEASE HELP?
I've worked on similar models with all manner of problems. Try unplugging the machine from the electrical outlet for about 30 seconds then, plug it back in. This will "re-boot" the control board. If it doesn't work, I'd say the control board is bad.
May 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Door wont open
Try pressing PAUSE\CANCEL . if it doesn't work , unplug the washer and wait 5 min before plugging it back in . It should reset it.
Mar 15, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door Locked after FA code
Press "end of cycle" button and wait for a click or 3 minutes, they try the door. Do not force door
Dec 28, 2007 | Whirlpool GHW9300 Duet Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
