Question about Microwave Ovens
Hi! Our dear friend - Jura Impressa F90 - is "stuck". It started making coffe: it grinded and then suddenly the tray was pushed out ab.1 cm and now there is only some part hanging down inside (I cannot describe it better, is there a possibility to send a pic?). Now nothing works. It only says "Tray missing" (as it cannot be pushed back). Thanks for any help!
  • roosi19 Apr 12, 2011
    Unfortunately this is not the solution in this case. As I wrote - the tray does not go inside - it's ab. 1 cm outside.
    I have sent the machine to repairs.
    Genius:
  • 1,622 Answers
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
sounds like the interlock is dirty . It's probably safe to give it a good soaking (unplugged) to get any coffee residue shifted.Give it a good scooshing at the base where the sticky out bit on the tray enters the base.
Also try out this .On the right side inside you can see a small slot. Try using a screw diver or something to click this small micro switch, if the message disappears, then you need to check your tray and see if something is broken. You can also try to move a little on the tray when it`s in the machine. However if clicking on the micro switch does not help, you need to have this switch replaced in a service center
Posted on Apr 07, 2011
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
My Keurig coffee maker will makes a grinding sound when the start button is pushed, the K-cup is in place, but water does not pour through into the cup.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 07, 2011 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Turntable Grinding Noise
It will need a new turntable motor. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 21, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
198 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
