Question about AEG Lavamat 74640 Front Load Washer
HOW DO I GET AT THE PUMP I have cleared all the filters and drain pipes but still the water is not being emptied I think there may be a blockage in the pump ' thank you
    Brigadier General:
  • 6,277 Answers
(try this!)
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Apr 07, 2011
My 17kg whirlpool x-pert is not spin drying
Is it emptying the water quickly enough? A blockage, or partial blockage on drain will prevent the spin starting quickly, and you only have a limited time on spin before the program stops.
Carefully remove and clean any filters if fitted on the drain - you must do this and don't assume they are clear. If ok, check the connections at the waste hose on the sink or plumbing, and in the waste hosepipe. Can you hear the drain pump running on the drain only cycle? a glug glug glug noise.... if you cant hear the pump it may be seized or jammed with a coin or button or pin or bra wire or zip etc etc.
If no waste water is flowing, try lowering the waste pipe on to the floor completely flat - water should flow out under gravity. If it doesn't, there may be a blockage in the machine sump hose - a sock or pants, etc.
Check all the basics first - water fill, water drain, filter clear, drain water flowing etc.... if all ok, may be motor or control card.
Dec 28, 2017 | Whirlpool Washing Machines
Lights 2+4 flashing on dishwasher & won't drain
Doe the pump make a sound as if it's trying to pump out? As it sounds as though your pump is either obstructed, or the outlet waste water pipe from back outside of the dishwasher to the drain, maybe bent somewhere or blocked & not allowing water to exit the dishwasher, if both are clear of blockages & no noise of the pump kicking in to empty the dishwasher then I would definitely say the pump has failed...
I hope this helps....
Feb 22, 2018 | Dishwashers
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
Nd error Washer will not drain. Had this problem before and removed coins from the pump all worked well. Now however there is nothing lodged in the pump and it will not drain.
get something to catch water in, then disconnect the outlet pipe and hold it as low as possible to the floor if water drains out, the pipe should be clear of any blockages. if it is re,connect the pipe...next turn the washer on and put it on empty cycle if you can hear the pump motor running and ,still does not empty the pump is probably damaged,if it is you will have yo have it checked out by the repair man
Jul 24, 2011 | Washing Machines
Water will not drain cannot open door
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front panel. If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Dec 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My machine wont drain or spin. if i maually empty, it will eventually start a wool wash but then says error e20 but filter is clean and no kinks or blockage in drain pipe. should i replace outlet pump?
Do the following.
1. Switch off the machine, unplug or disconnect the mains AC power to the machine and turn off the water supply to the machine.
2. Remove the filter access panel.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 13, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
Our wm-16225fd does not spin/drain.I have fitted a
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 15, 2009 | Washing Machines
My candi combiwash will not empty
see if pump is turning check pump and drain hose for blockage also door switch or timer
Aug 15, 2009 | Washing Machines
Washer won't drain
Well if you put your waste pipe to ground level whilst the machine has water in it (with the machine off ). If the water empties then yes your pump is bad. if not you have a blockage in the filter .
Although you said you cant see a blockage.
if you need any help dont hesitate to ask
Dec 27, 2007 | Frigidaire GLTF1670A Front Load Washer
AEG Lavamat 74640 Front Load Washer Logo
268 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
