Question about Kenmore 63942 Dryer
Dryer Hum I have a Kenmore dryer that will turn on, and the drum rotates. I has, however, developed a hum when turned on. I haven't left in on but for a couple of minutes so I don't know if it is heating up. What should I look at first for repair?
  • 481 Answers
Usually this is a sign of a bad motor.
Posted on Aug 11, 2008
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
When I push the start button, the dryer does not come on, but it just hums.
Check to see if you can rotate the drum. if you cant then you need to check the blower wheel. If you can then hold the door switch in and start the dryer. if it starts to hum rotate the drum while holding the door switch in. if it runs on it own after you rotate it then you need a new motor
Jul 12, 2011 | Kenmore 600 6963 Electric Dryer
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
Drum will not rotate
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Kenmore 83142 Electric Dryer
When you turn on the dryer you can hear the motor hum but the drum wont turn ...i checked the belt and it is not broken
When you checked the belt, did you check to see if the motor would turn by hand, if not the motor is locked down and that's why you hear the hum noise, it still has power and still trying to rotate, but from being locked down it has no option but to strain and hum. If that's not it, check around the drum for a sock or small piece of clothing, it can wedge between drum and dryer frame and cause the tub not to rotate just like if the motor were locked down.
Jan 06, 2010 | Washing Machines
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Kenmore Dryer
the bearings in the motor are locked up. they are sealed so you have to replace the motor to fix it.
Nov 25, 2007 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
