Question about RCA Televison & Video
Problem: How do I get my RCA DVD player door to open? I tried unplugging the DVD player, plugging it back in, and then pushing stop on the DVD player and then open.
    Sergeant:
  • 174 Answers
You put a small long pin in to the holl which you can see just below the door and push to the lever so that the door lock will open, then you check and replaced the rubber belt if required
Posted on Apr 07, 2011
Why does dvd door keeps opening and closing on rca tv
UNplug the machine wait 10 secs plug back in
It might work unless sensors are dirty or shot
To much trouble to fix it, especially if it is incorporated in tv
Try blowiing a blast of air inside when door is open
good luck
Feb 06, 2012 | RCA Televison & Video
How do I get my RCA dvd player door to open?
I've had some luck with unplugging the DVD player, plugging it back in, and then pushing stop on the DVD player and then open. See if that works. Sometimes it just locks up like a computer.
Feb 20, 2011 | RCA Televison & Video
I have a RCA RS2664B 5 Disc Player and the disc door won't open and you can not play CD'S. Help!!!!!
unplugged the unit for 5-10 mins........ when u plug it back to ac outlet....press the stop/eject...the cd player by default is trying to load the disk again...you wish to open the disk tray..once all disk are recover try another disk to play
Sep 12, 2010 | RCA Audio Players & Recorders
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
Disc won't eject
The problem is either the dvd door motor is bad or the control board is having program issues. You can remove the screws to the cover of the player. Lift cover off and manually open the door and remove the disc. It is also possible that by manually pushing the door open will put the door gears back into alignment. If it doesn't it should be tested and repaired
Apr 24, 2009 | RCA DRC8335
DVD player is locked!
Unplug for 5 min then plug back in... now press and hold the powers button for 15 seconds...thts should fix ya!
Dec 12, 2008 | JVC XV-N320 DVD Player
Jvc dvd player
press and hold stop button more than 5 sec and ur player will be unlock
Nov 08, 2008 | JVC XV-N320 DVD Player
DVD stuck in DVR5000
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Nov 19, 2005 | Rio DVR5000 DVD Player
Televison & Video Logo
106 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
