Hi, The one channel on my NAD 3240PE cuts out completely after about 20 minutes of use (no sound whatsoever). I suspect overheating of some component as play time is shorter when it is hot (summer). Kindly advise on possible repairs.
  • 60 Answers
You should check for dry joints near the amp ic.
You should also check R414, R424, R441, R442, R413, R423, R445 and R446.
Hope this helps.
Posted on Apr 07, 2011
Testimonial: "Thanks for the assistance, will certainly try it."
  • stickyc
    stickyc Feb 28, 2014
    NICE blanqui2000 you're my NAD 3240 PE savior, changed all mentioned resitors, turned out that 3 oout of R413,414,423,424 were defective. Amp plays clean again, THX A BUNCH :)
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
NAD C370 distortion.
It looks like you may shorted some part of the audio circuitry, Most likely you will have to replace the entire board (easier option).
If you can find a replacement board, it shouldn't be too hard to replace, if you have had prior experience with electronics. However,i think it is best you let an experienced electronics repair guy do this for you.
hope that helps..
May 25, 2008 | NAD C370 2-Channel Amplifier
Amplifier cuts of after 20 min playing
Sounds like a component inside is overheating. Might suggest taking to a car adio specialist to fix but could be expensive to repair. A new replacement maybe cheaper.
Sep 02, 2012 | Car Audio & Video
My left channel goes out on my 533, when I touch the RCA in the back, it comes back on for a few minutes then cuts out again???
You need to replace the RCA plug with a new one. If it is on a seperate cable replace the lot, if not cut it off. There are only two wires one earth and the channel, you can't go wrong.
Dec 04, 2010 | NAD 533 Turntable
Hi, I have a second hand NAD 3240PE amplifier, the right channel has an intermitent crackle but the left channel is fine, Any ideas as to what might be causing this problem?
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Dec 28, 2009 | NAD Audio Players & Recorders
No sound from amplifier on both channels
Hi...
All the main power supply capacitors need to be replaced.
I'm figuring it's an older unit?
Let me know
Thanks,
Scott
Mar 23, 2009 | NAD Audio Players & Recorders
Is there a reset button for the NAD Surround Sound Receiver T 751
The only reset that i know of is to unplug it for 15 to 20 minutes. Hope this helps.
Dec 03, 2008 | NAD T751 Receiver
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Sound cuts off
OK,  That means there's some kind of crazy fault in the temperature sensing circuits. I'm afraid you'll have to take it someplace and have it looked at for a more thorough diagnosis.
Aug 31, 2008 | NAD C325BEE Amplifier
Nad 302 amplifier
sounds to me that the vol control has lost its earth end connection So yes its a problem with the dial control You couls try some contact cleaner But better still lift of the lid and base if possible while the amplifier is not plugged into the power socket and see if you have a dry joints around the vol control pot regards Trev
Mar 14, 2007 | NAD CI9060 Amplifier
362 people viewed this question
 Grubhead
Grubhead
