Question about LG LSC121PMA Split System Air Conditioner
Hi I'm trying to get the air conditioning on but I can't light is flashing on the airconditioning and 12pm is shown in remote control Could u help me to sort this matter out I have three LG neo plasma in 3 different rooms and I'm trying to get them on but I can't
We have the exact same problem with our unit. Can't find solution. Any chance you have found out the cause? We also have 3 units, in 3 different rooms. The air vent's are in our garage.
Posted on Apr 22, 2011
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
Hi.... My Air conditioning remote control AR-DL1 doesn't seem to be working.It's been working on and off for a while,but now ....Nothing at all ( I changed the batteries also ) .Since I don't know if it's...
Remove batteries and keep for 5 minutes. And also remove DC wire plugged in display sensor in your indoor unit. Now, plug again DC wire in same position and also put batteries in remote. Power on and try now. In many units, this type of resetting would help. If still problem, check remote thr' camera mobile by pressing any button in remote. If ultra light flashes, remote is o.k.You have to repair/replace PCB only. If no ultra light, replace remote.Thanks.
Feb 01, 2011 | Heating & Cooling
I just buy an lg aircondition with remote when 1 of my family member accidentally throw out the manual and the remote...please help...what should i do to have new one?
Call Lg and have the model number of your air condition. They may send you one for free if you explain what happened otherwise you may be charged. Also go to where you bought the air condition and they may have generic programmable remotes to work with your lg air conditioner.
Aug 17, 2010 | LG Kitchen Ranges
I have an E1 error on my airconditioning unit...no remote and no access to get one...is there anything I can do?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 16, 2010 | Haier HWC08XC1 Wall/Window Air Conditioner
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
Kenmore a/c remote control doesn't work
Google AirConditioning remote controls. Go to parts warehouse and check there. I have purchsed two remotes for different AC units on line for about 50 dollars.
Jun 08, 2009 | Kenmore 75085 Air Conditioner
TURNED OFF AND 5 WAY LIGHTS ON AIRCONDITIONER FLASHING, WON'T TURN ON
1.check selector switch.
2.wiring.
3. check cirkit board of aircondition
Jan 29, 2008 | Heating & Cooling
Heating & Cooling Logo
394 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
