Question about Makita & Plunge Router
Makia rp180x/11/2 wat is the amps to this product
What does the 24wh mean in a makia battery bl1815 18v 24wh
It is a measure of the energy contained in that model of battery
24Wh means that it could deliver 1W for 24 hours, or 24W for 1 hr or that it is able to store 24 x 60 x 60 J or 24 x 3600 / 4.18 calories.
12.February.2015
Feb 12, 2015 | Drills
Can you tell me how to conect my yamaha espeaker sw218v,do i need two.1200.wat amps.one for each one ordo i need a 1400,wat amp in order to have them work perfect or close to perfect!!thankyou...
Power handling CAPACITY is not to be confused with power requirements. What they're getting at in the box "To protect your speakers" on Page 3 in the manual ...
When choosing a power amplifier to use with your speakers,
make sure that its power output matches the speakers’ power
capacity (refer to the Specifications on page 6). Even if the
amplifier’s power output is lower than the speakers’ PGM
(program) power capacity, the speakers may be damaged
when clipping of a high input signal occurs."
...is that any amplifier driven beyond it's non-distorting power limit will damage any speaker system, not with its raw power but with the artifacts of distortion (clipping). So they recommend amps spec'd at those high ratings in an attempt to keep them from distorting due to overdrive.
In practice, if you're cranking an amp to the stops you're either overdriving it or you're performing a concert and wishing you could crank it to '11'.
Being nominally 4-ohms, a pair of these speakers would likely have to be run in series or else their effective impedance may drop dangerously low. Two amps may be better for you, one amp per subwoofer.
If you need the manual, register with retrevo.com and download it free using "Yamaha SW218v" as the search.
Feb 05, 2010 | Yamaha SW218V Speaker
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I cant store video recroded in my phone directly to memory card i.e video lenght not more than 11 mins.. wat should i do for recroding video more than 15 mins and so on i.e abt 1 hr... Please help me this...
each phone has his fix internal mem. no one can change it. i thk its internal mem. supports the video rec. only upto 11 min.s & not more than that. we cant do anything in that case.
u also check ur video rec. setting, something wll find there.
Jul 05, 2009 | Samsung SGH-D900 Cellular Phone
Amp in Protection Mode
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 19, 2007 | Nitro BMW-482 Car Audio Amplifier
CD changer problem
According to the manual, error 11 means the disc is inserted upside down.
Oct 11, 2007 | Pioneer CDX-FM1289 12-Disc CD Changer
Dont no wat size fuse for lead
depends what wireing kit you are useing.if you are useing say a 300watt kit then the fuse in the main power lead is normally a 25amp fuse,and this should be installed a maximum of 12 to 18 inches from the batery. hope this helps.
Feb 19, 2007 | Solid Audio Maniac Series MS2 2-Channel...
Makita & Plunge Router  Logo
20 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
