Question about Dishwashers
Hi! when the machine is switched on, it displays " CODE 1--- " and on touching the on button all of them go on then off. Only the cycle one button indicator that lights very deem. What could be the problem Rgrds, Kanyingi.
  • 1,998 Answers
Could be the thermal cutoff fuse or the touch pad or a bad erc would need to do some power and continuity tests with a multimeter to assure which piece is working properly and which is not would need the model number for your unit to provide schematic of your unit if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Apr 07, 2011
Machine does not power up
The fuse is located in a little black box underneath the base of the machine, but it is not an easy job to take the box out, disassemble it, replace the fuse, and then reassemble the whole machine. I suggest you take it to a service center.
Aug 31, 2008 | Janome Memory Craft 4000 Sewing Machine
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
I have got a westpoint washing machine XQG50-604 the water switch is faulty but the machine is working it doenst pour water on the machine at all.rose e-mail:rntuli@uj.ac.za
Hi
I have a Westpoint front loader washing machine, model number XQG50-604. The power button got stuck, opened machine up and find the power switch burnt out. Where is Johannesburg in South Africa can I get a new switch please? Also can you advise how to remove old switch and to replace the new switch.
Regards
Juanita
Feb 15, 2011 | Washing Machines
Trying to relpace the on/off switch on my solis crema sl70. I have the machine apart, but can not get the switch out of the face plate. Anyone kn ow the secret?
Hi The foil on the front has to peel back until the switch will push out the front. Peel from a corner. Make sure that the switch goes back in the same way.
Feb 17, 2010 | Solis Crema SL-70 Espresso Machine
Top loading machine will not empty water or spin
Hi, check your fuse or circuit breaker in your house panel, check make sure there's power in your washer receptacle,(outlet,socket). if there's power in washer receptacle, check machine lid switch first, lift (open) top of machine, look under area covered by lid, switch should be located there, you did not say what model or make of machine, i could be more accurate in helping you find lid switch. check lid switch first, if lid switch o/k, you will have to make more checks, check for breakage, damages machine plug, check from plug all the way to where it is connected inside of machine, check your timer, any printed circuit boards , check machine water level switches, and all other switches, until you find (faulty one) problem, also check motor, and motor capacitor. if you have to reach that far. but first check simple, basic things, make sure power to machine, check lid switch., always remember, disconnect power before doing any repairs, let me know what happened., you can empty your machine by lowering drain hose close to floor. by gravity, use bucket, or something to collect water from machine.. good luck.
Aug 15, 2009 | Washing Machines
Fault with draining washing machine
hi,
verify lid switch function first. you can bypass lid switch with jumper wire. unit will not spin out if lid is open. if switch goes bad it thinks lid is open when it is actually closed
Jul 05, 2009 | Washing Machines
Washing machine wont spin and only drains when it wants to
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Jun 19, 2009 | Washing Machines
It filled with water then just stopped? No spin or rinse.?
It seems Lid switch -
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Good Luck.
Thanks
May 16, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Saeco Vienna no function
Your main bord is the problem, you have to replace it with a new one:-(
Apr 08, 2008 | Saeco Vienna Espresso Machine
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
