Question about Dryers
My dryer runs and drys but after a little while it will trip the breaker in the electrical panel. Anyone have a clue? It's a GE mod.# DLLLR23EG1WW. Thanks in advance for any help. Tom
    President:
  • 1,273 Answers
Hello, W/D here.
When a machine is operating properly, but then trips the breaker, the breaker itself seems to be suspect. Breakers wear over time, and can become "weak". Also, amps on a breaker are time weighted. The more amps that you pull, the less time it takes for the breaker to trip. This is also true with a weak breaker. Check the amps that you should pull with your dryer, and check the breaker. If the breaker is the correct size, try replacing it. You should be on a 30 amp breaker/circuit.
Here are some useful links for your dryer:
Owner's manual http://www.managemylife.com/mmh/owner_manuals/6276/GE-Residential-Dryer-L0707113?brand_name_search=DLLLR23EG1WW+GE Installation guide accessible from same link.
Parts manual http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DLLLR23EG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DLLLR23EG1WW
Best regards, --W/D--
Posted on Apr 07, 2011
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
Gas Dryer tripping circuit breaker
YOU HAVE A CROSSED WIRE CHECK METAL CLIP IS NOT IN CONTACT WITH ANY EXSPOSED WIRES AND MAKE SURE IGNITER IS PROPER POISTION .
Oct 22, 2009 | Dryers
No heat in electric clothes dryer
sounds like the typical heating element problem,which is located behind the drum.
Sep 08, 2009 | Dryers
My GE dryer DHDSR46EG 1WW less than 2 year-old dryer flips the breaker after about 10 minutes of drying
If the dryer appears to be running OK before the breaker trips, I might consider checking the breaker. Over time they can get weak and not hold the current rating.
If the dryer is smelling "hot" then we can look a little further.
Let me know.
Regards,
Aug 15, 2009 | GE Dryers
Asko 24 el dryer does not run,no indicator light,Mod 10776110,LMBent
Check the house electrical panel for tripped dryer breaker pair. Push off, then on to reset. If breakers trip again, you have a short circuit within the dryer case--usually the heating element(s).
Aug 07, 2009 | Asko T701 Electric Dryer
Motor is very loud
PRY THE TOP UP AT THE EDGES BETWEEN THE TOP PANEL AND THE FRONT PANEL. LUBRICATE YOUR REAR BEARING
Apr 09, 2009 | GE DPSB519EBCC / DPSB519EBWW Electric...
I get e01 on ge dyrer panel
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Aug 22, 2008 | GE DCVH515EF Electric Dryer
Washer ge wprb9110dww
Hi! mastermech51
If I understand the main difficulty is the breaker trips on the main breaker panel? If this is so have an electrician check the current or amperage draw at the breaker panel when the washer shuts down. It could be just a loose terminal on the breaker, or a bad breaker. This also is dependent on what other loads are on the washer circuit.
InMrFixIt
Jul 24, 2008 | GE DBSR453EBWW Electric Dryer
Dryer intermitantly drys.
I have replaced several blower motors on these units for that problem. If the board doesn't read the blower motor speed it won't turn the heater on.
May 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
104 people viewed this question
Top Dryers Experts
