Question about OKI C8800dn Led Printer
What does Fatal Error 173 mean on an OKI C8800?
lafalot
  • 152 Answers
SOURCE: Hi I have a Oki
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Posted on Feb 03, 2009
  • 628 Answers
SOURCE: fatal error 173?
It points to an internal error. It may be from the fuser unit. Make sure all the wires are connected praoperly and that you didn't disconnect anything when you repalced the fuser. If the problempersists, you'll have to take it in for service.
Posted on Aug 22, 2009
  • 152 Answers
SOURCE: I have a OKI C5500N, keep getting the message
1. Remove All files that were installed before 'fatal error' using 'Printer Util.exe' or similiar file available in your CD.
2. Install software 'Dial-A-fix'. (Dial-a-fix is a collection of 'known fixes' that have been compiledover the past year that really knock out some serious Windows problems....)
http://www.download3k.com/DownloadLink1-Dial-a-fix.html
3. Run the 'Dial-a-fix.exe' Software and select 'Fix Windows Installer' & 'Empty Temp Folder' options and click 'Go' button.
4. Restart your computer, run the your printer CD, you should have no problem. (don't connect the printer/device until the cd Setup prompts you to)
Posted on Nov 10, 2009
  • 13 Answers
SOURCE: oki b4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Posted on Feb 24, 2010
  • 51 Answers
SOURCE: What is 173:fatal error on my oki c5700?
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Posted on Jul 04, 2010
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
CAN ANYONE TELL ME WHAT 173:FATAL ERROR 2A14 MEANS?
Your Fuser is not getting to temperature. Make sure the printer is plugged directly into a wall outlet. If it is then you need to replace the fuser.
Jan 11, 2011 | OKI Electric Industry B4600 Laser Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 173?
Aug 20, 2009 | OKI C5150n Led Printer
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
Jan 27, 2009 | OKI C5100n Laser Printer
Fatal Error Code 173 - OKI 5100 copier
173 is a fuser upper roller low heat error.
Nov 19, 2008 | Office Equipment & Supplies
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
OKI C8800dn Led Printer Logo
604 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
