Question about Dell 1720dn Laser Printer
I HAVE PRINTER DELL 1720 ALL LIDHTS ARE FLASHING
    Problem Solver:
  • 10 Answers
Did you just upgrade your printers memory
Posted on Apr 07, 2011
The yellow light on the front keeps flashing and it wont print
It helps SO much when you include the Model number of the printer you are asking about. If it happens to be a Dell 1720 then simply push the tab down located at the top right of the output bin. that Tab sticks open can cause the light to flash.
Oct 09, 2011 | Dell Office Equipment & Supplies
All the lights on my Dell 1720 printer are flashing
Try unplugging the printer for fifteen minutes or so. If that doesn't do it then it it your main board. Sorry for the bad news.
Apr 27, 2011 | Dell 1720dn Laser Printer
I have a Dell 1720 printer and a light is flashing to indicate that I need to remove the output, and nothing I do makes the light stop flashing so I cannot print anything.
On the top where the paper comes out is a sensor. There is a flap with an arm attached that passes thru a photo-sensor. make sure the flap is not stuck in the up position and make sure the little arm is not broke off. You will need look very closely
Aug 18, 2010 | Dell 1720dn Laser Printer
How do I Adjust the Printer Margins for Dell 1720 I am printing on insurance forms and the print is too high and to the right
I have found a good manual that can help you easily with the help of pictures.
Click on the link below to access it :
ftp://ftp.lexmark.com/depot/Dell/Dell_1720_Depot_rev061807.pdf
In case of further help let me know
Mar 21, 2010 | Dell Laser 1720 Printer
All Lights Flashing
I found out this is caused by the touchpanel on the top.
Oct 27, 2009 | Dell 1720dn Laser Printer
1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
GOOD LUCK, EVERYONE!!!
Mar 12, 2009 | Dell 1700n Laser Printer
Dell 1720 flashinf replace drum- error.
The second link was the helpful information. Also, to cut through all of that --
If you need to reset the counter:
1. Remove drum kit with toner
2. Make sure all print jobs are flushed otherwise whatever has been sent and not printed will come spewing out.
3. Hold down CANCEL Button until all lights flash through.
4. Slide the drum kit and toner properly into the Printer.
done.
Mar 03, 2009 | Dell 1720dn Laser Printer
DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Sep 18, 2008 | Dell 1700n Laser Printer
Dell 1720 usb port printing problem
You can get a usb adapter to printer comp ports on ebay eBayeBay
Sep 20, 2017 | Office Equipment & Supplies
Dell 1720dn Laser Printer Logo
48 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
