How can i access/enabled USB for LG 32LD330 and where can i find the service menu for it? tnx! =)
3 Suggested Answers
Dumaine
  • 112 Answers
SOURCE: I have a LG 42LD450, I read and saw videos online
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
Posted on Dec 11, 2010
SOURCE: I have the lg 42ld450
Hi my nameis Mike Houston of DISH Network and I see you are trying to play movies throughyour LG TV. I will send a link to help program the remote to the LG TV, http://www.dishnetwork.com/SupportSection/power-scan-instructions.If the DISH remote is programmed to the TV and you still can not get into theService Menu you will need to refer to the TV manufacture, I will send the linkto help with that, http://www.lg.com/us/support/index.jsp.
Posted on May 09, 2011
I want to activate my USB tv Port on that model, and cant .
This should be in the settings menu on your TV. Just like a computer you need to format the drive for the TV.
Nov 14, 2015 | LG 32LD330 MULTISYSTEM LCD FOR 110-240...
What are the steps to activate movies from usb port on my lg 50pg60ud model
The Pg series cannot play movies from Usb they have no processor for that
The first to have this were the Pq and then you could do this kind of hack
Sorry
Aug 17, 2014 | LG 50PG20 50 in. Plasma HDTV
How do I access the lg 55la6200 service menu?
you need a service remocon to do this there is no other way
(I mean there no other way pushing buttons etc )
Jun 14, 2014 | LG 55LA6200 55" 3D 1080p LED-LCD TV - 16:9...
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
Internet not work.
The user can surf the internet as the KP500 cookie mobile phone supports HTML/XHTML and WAP 2.0 web browsing technologies, providing speedy connections. The EDGE and GPRS technologies provide not only a speedy service but a good quality of service especially for data transfers. The user can connect their LG KP500 mobile phone with ease to other compatible devices with the USB and Bluetooth with A2DP technologies. The KP500 operates on a Quad-band network and covers GSM-850/900/1800/1900 enabling the user to use the roaming facilities as and when abroad. The LG KP500 supports a document viewer which enables the user to view documents in XLS, DOC and PDF formats.
To Setup the Access Point
  1. Go to the Main Screen
  2. Select Menu (the 4 dot button)
  3. Select the Settings tab
  4. Select Connectivity
  5. Select Access Points
  6. Select Add access point
  7. For the Connection name enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Authentication to This option varies on devices but typically is similar to the setting provided.
    ">#Authentication
  9. For the Username enter The Username for the connection provided by the Carrier.
    ">#Username
  10. For the Password enter The Password for the connection provided by the Carrier.
    ">#Password
  11. For the APN enter Access Point Name - Similar to the server the connection uses for the connection. Different APNs provide different services.
    ">#MMSAPN
  12. Select Save
To Setup the Internet Profile
  5. Select Internet profiles
  6. Select Add profile
  7. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Use proxy to AT&T:
    • On
    T-Mobile:
    • Off
    • Alternative: On
      Note the proxy only needs to be on if using the Alternate settings
    ">#Proxy
  9. For the Proxy server address enter The Server address to use for the connection.
    Some devices require the address in the format of 000.000.000.000. (ex: 011.012.013.014)
    ">#MMSProxy
    if the Proxy is on
  10. For the Proxy server port enter The Port number used by the connection.
    ">#MMSPort
    if the Proxy is on
  11. Set the Access point to the profile created above
  12. Select Save
To Setup the Browser Profile
  3. Select the Utilities tab
  4. Select Browser
  5. Select Settings
  6. Select Profiles
  7. Select Add profile
  8. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  9. For the Homepage enter Can be set to anything if an Internet Plan is on the account such as www.google.com
    ">#Homepage
  10. Set the Internet Profile to the profile created above
  11. Select Save
  12. Select Yes to Activate
  13. The internet should now be configured
Jan 25, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
I have a LG 42LD450, I read and saw videos online showing that you can enable video playback through the USB port. I also read that u need a certain universal remote to access the service menu does anyone...
Dec 04, 2010 | LG 42LD450 42 in TV
My lg viewty wont let me access the contents through the lg pc suite. Its keeps coming up with invalid access too memory location. How do i fix this?
Go to 'Menu > Settings > Connectivity > USB connection mode', and select 'Data service'.
Hope it works for you.
Cheers! Carlos
Mar 18, 2010 | LG KU990 Viewty
32LG3000 TV LCD - usb port ''service only''
Yes it's possible to use the USB port , you only have to change settings in TV setup to change it.
With software ver 3.15 it's very easy see link below how to change setup.
http://lgusb.wikispaces.com/#support
Feb 23, 2010 | Televison & Video
Televison & Video Logo
823 people viewed this question
Top Televison & Video Experts
