Question about Cell Phones
The SIM card does not fit into the opening. It extends widthwise over the open shiny metal area onto the black area. Is this okay, so long as the gold metal section is on the bottom?
  • 29 Answers
Without any disturbance for gold contact you can cut it off the plastic area of the SIM card and use.
Posted on Apr 07, 2011
How do you put a sim card in
Depending on the Phones Make and Model and what type of SIM card you are NEEDING if SIM card didn't come with PH?
You can go online and look at diagrams of the Various SIM cards. Most SIM card fit Behind the Battery of your Smart PH. You must carefully remove back of ph most smart phone have a small indention to assist with removal? If not either use your nail or THIN OBJECT (Fake Nail Tips Work Great, Even your Nail, plastic/Wood Tooth Pick or any thin enough non metal to open seal ) Then carefully remove back of ph then Battery the SIM card slot will either be on the side or Top or bottom behind Battery space Slide Sim card in with Metal connector sides down in direction indicated then replace battery and back of ph. Some Phone come with a Internal SIM Card for Programing of phone, the other SIM card Slot is for Memory make sure if this is what is NOT Situation your PH? Some even have Duel SIM Slot they Usually can be programed with either type of SIM Card Purchased these are for the new I call Free-agent Phone meaning you Purchase your Phone and Choose your Carrier Such as Straight Talk ect.
Apr 01, 2017 | Cell Phones
How to install video card?
Hello Ruel
I have step by step procedure about installing video card.
1. Turn off your PC, unplug it, and remove your computer's case. "Your computer should have either a PCI-Express 16x or AGP slot for your card. The card won't fit into the wrong slot, so you can't go wrong. But don't confuse your computer's thin memory slots for its video card slot."
2. With a small screwdriver, remove the screw holding in the old card or the metal cover. "Don't lose that screw! You need it to secure the new card in place."
3. If you're replacing an old card, pull it up and out of the slot (left). "If you're not replacing an old card, remove the metal cover from the back of your computer (right)."
4. Hold the card by its edges and position it over the correct slot. "The edge with the shiny metal bracket should face toward the back of your computer. (That shiny bracket replaces the cover, if you removed one.)"
5. Line up the tabs and notches on the card's bottom with the notches in the slot. Push the card slowly into the slot. "You may need to rock the card back and forth gently. When the card pops in, you can feel it come to rest. Don't force it!"
6. If the video slot has it, bend out the flexible plastic retaining clip that fits over a tab on the end of the video card. "When the card fits into the slot, release the clip, letting it hold the card in place."
7. Secure the card in the slot with the screw you removed in Step 3, then plug the computer back in, turn it on, and see whether Windows recognizes and installs the card. "Windows usually recognizes newly installed cards and sets them up to work correctly."
8. If everything's working, put your PC's cover back on. "If something goes wrong, turn off your computer, unplug it, and make sure you've seated the card correctly."
Be careful not to touch any chips. Touch as little as possible on the video card or inside your machine.
If possible, do the installation in an non-carpeted area to avoid static.
If possible, use the slot with the most open space around it.
If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the video card for you.
Best Regards
Neciforo Llanto
Sep 21, 2013 | MSI RC410M-L Motherboard
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
Places of simcard in LG model cx9200
  • Power off your cell phone.
  • Remove the back battery plate. Depending on the make and model of the cell phone, you will either have to slide the panel off by applying pressure with your thumb or by sliding a small latch and then removing the plate.
  • Take out the battery.
    Look for the SIM card door. It will be shiny, silver and will be clearly marked. You'll also be able to see your SIM card.
  • Open your SIM card door by sliding it open (follow the arrow directions on the door) and sliding out your SIM card.
  • Apr 24, 2011 | LG Cell Phones
    How to open insert the sim card and how to open the sim tray
    with the screen facing you, the he sim tray on the iPhone 4 is along the right side half way down the metal frame. On all previous iPhones it is on the up center.
    1. Once you have found your sim tray, insert a small paper clip into the hole
    2. Slowly push in with even moderate pressure.
    3. The tray will pop out and you will see your tray and sim card.
    4. when replce=ing the card into the tray, the label side should be facing the screen side of the phone.
    5. msovesky_0.jpgmsovesky.jpgRepalce it by simply reinserting the tray the same way it came out.
    Feb 15, 2011 | Apple iPhone 4 Black Smartphone
    How do I insert the sim card, can't open the phone and no instructions came with it?
    Open the back lid where the battery is. Face the screen and on the right side you will see just above the camera button a part from the shiny thing can be pulled. Just use your nail and push from where the case from front meets the shiny siding. It will pop up towards back. Careful it doesn't come completely of. It will be like going through a page. No face the sim card with the gold side facing against the screen and slide in.Good luck.
    Feb 12, 2010 | HTC Touch P3450 Smartphone
    Dont know where sim goes
    Take out the battery and the SIM card should be under it.
    Mar 11, 2009 | Nokia 5800 XpressMusic Smartphone
    How do you replace the sim card on a nokia 2125?
    The problem is that the 2125 is a CDMA phone and doesn't use a sim card. You can slide a sim card onto the inside of the metal casing that flips up but the phone lacks the components to reach the metal terminals on the sim card and thus read the sim card.
    Nov 27, 2008 | Nokia 2125 Cellular Phone
    I don't know how or what to open in the Nokia 2125 to change the sim card. We have removed the battery and flipped up the casing at the bottom of the battery cavity, but cannot see any other movable parts...
    Hampton Bay 54in. Covington with remote control
    Make sure the power wires from the ceiling mount are still in the electric box. Then have them come from the side near the screw mounting area. In otherwords, not through the center hole. In the center of the black metal part - there is where you put the reciever. It will fit literally resting on the black metal.
    Aug 31, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
    Cell Phones Logo
    23 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
