Question about IBM xSeries 346 Server
I have one server IBM X series 346, which is giving Fan alarm , its fan LED showing amber, though server is working fine.
  • 1,719 Answers
Checkout the fans inside the server. They may not be running and in this case you need to replace the faulty fan (if any).
Moreover, there may be dust inside the server chasis which requires cleaning.
Hope it helps! Good Luck!
CreativeTECH
Posted on Apr 07, 2011
  • IBM Master
  • 32,281 Answers
The problem could be a faulty CPU fan or the fan and heat sinl assembly is clogged with dust.
Check the fan, if it does not spin freely then replace the fan. If the fan and heat sink is clogged with dust, remove the dust and use a can of compressed air to clear the dust from the heat sink fins.
Ibm xseries 205 reboot after begin the start
Check server has amber on it. If so inspect FAN and replace same if it has amber.
Mar 16, 2013 | IBM eserver xSeries 205 8480
Problems with IBM Xseries 346 Server
Check Light Path Diagnostic which is located on the front side of server . It gives a clue of what's the issue . If you can't see any amber on Light Path Diagnostic , then its an indication of max logs logged on BIOS event logs. You may need to restart server > Get into Bios and clear all event logs . This would remove the information sympol from server .
Jul 31, 2012 | IBM xSeries 346 Server
Fans wont work ibm x3400
Remove fan that is having Amber from Fan bay . Clean fan slot as well as bay slot . Then Refix it . It will work .
Feb 20, 2012 | IBM x3400 Server
Ibm raid controller drivers for x series 346 server
I have a problem with x346 server i need raid drivers for windows server 2008 32 bit please if some one can help/
May 13, 2011 | IBM xSeries 346 Server
I have an IBM x346 eserver that has run well for years. The fans are now very load (whirling noise). I typically only hear this noise when the room temp is high, but this server is in a cool room with no...
It sound like the CPU fan or server case fan/s or power supply fan bearings are worn.
To determine which fan/s is faulty open the computer case and stop each fan from spinning, one at a time to determine the noisy fan. Once you have identified the noisy fan then replace that fan.
Feb 07, 2011 | IBM xSeries 346 Server
Exclamatory mark led glowing in amber on the front panel It is IBM server 3400
Welcome to fixya
Amber led glows when server met with hardware issue. You will have to run the IBM DSA tool inorder to find the hardware that has issue.
Thanks
Nov 16, 2010 | IBM x3400 Server
X 346 powers on, then shuts down - no HDD installed
Even without the harddrive, you should be able to see the server power up with Bios/Memory test. It should be able to indicate to you that no drive found. In addition, you should be able to press F1 or F2 to enter into system setup.....hope this help
Jun 06, 2010 | IBM xSeries 346 Server
The fan light indicates a problem in xseries 346 and the fan rate is very high )there is high noise from the fans. what can be the problem?
There are many fans in servers. If one dies the others will work overtime to keep it cool. It sounds like you lost a fan somewhere.
When the server starts up you may see a POST message on the screen pointing out which fan failed. Otherwise, remove the cover and look for a failed fan. Be careful not to leave the cover off for very long. The cover is what makes sure the air flows correctly over the components.
If this helps please vote for my solution.
Aug 26, 2009 | IBM xSeries 346 Server
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
Ibm x346 single 2.4 intel xean processor
Hold down F & J keys when booting your server.
Feb 20, 2008 | IBM eServer xSeries 346
IBM xSeries 346 Server Logo
372 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
