Question about Yamaha Audio Players & Recorders
Recently bought new amp. Yamaha RX-v1067 how to adjust bass as I cannot hear anything. I have Bose am10 speakers
    Brigadier General:
  • 8,546 Answers
I have four Bose 161 speakers and an Acoutismass 5 bass unit (original cubes are bad and replaced with the 161s). My Onkyo receiver started turning off and going into protect mode recently. Bought new...
you're going to need a ohm meter (good electrical testers have them) and make sure ohm ratings from speakers match the ratings for your receivers. Sounds like to much resistance for receiver(s)
Jan 06, 2011 | Bose 161 Rear Speaker
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
Hey, i have an yamaha rx v496
As long as you can connect the audio to the RX, no need for another amplifier.
Mar 01, 2017 | Yamaha RX-V396 Receiver
No bass response
Seems there are 2 underlying problems-
no am/fm? are antennas connected? is there static active on any station tuned to?
in terms of low bass response- double check settings both in the receiver and also on the sub itself if any available.
Jan 14, 2010 | Bose Acoustimass 5 III System
Which bose speakerls will be good for my new yamaha RX-V863 amplifier?[for 7.1 channel Is it ok 6.1 channel for this amplifier?
You can hook up any speaker configaration you like, just select how many speakers you have on the Yamaha menu. If you use tiny Bose speakers for your left/right/centre make sure you select 'small speakers' on the Yamaha menu then all bass will go to the sub.
Aug 10, 2009 | Audio Players & Recorders
Bose home theater
It may not have bass and treble controls, since most newer TV's now have these adjustments. Play around with your TV and see if you can find bass and treble adjustments from the remote.
Dec 24, 2008 | Bose Cinemate Digital Home Theater System...
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Not sure woofer output is working or not
on a subwoofer, you normaly dont get sound you just get the bass from the music or movie,
Oct 22, 2008 | Yamaha RX-V661 Receiver
RX-V2090 Bass Output Problem
A couple things to check on the no bass problem:
1) Make sure your center speaker is set for normal, not large.
2) Make sure your speakers wires are in phase (+ conn. to + and - conn. to -).
Jun 23, 2007 | Yamaha RX-V2090 Receiver
182 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
