Question about Ovens
Stoves 600G SWITCH ON GRILL AND OVEN STARTS SPARKING AND CONTINUES UNTIL GRILL IS SWITCHED OFF.
Ewan ko po
Posted on Apr 07, 2011
How do I fix a continuously running upper oven fan
Without knowing the make and model, this is a guess, the fans usually run for some time after switch off, to allow cooling I am guessing this carries on until you isolate the mains. If so you have a thermostat problem. It would be easier to de-fine if there were more information.
Regards
John
Oct 31, 2014 | Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Jul 26, 2011 | Stoves 720EF Electric Double Oven
I have a 36'' Wolf LP oven with 4 burners and a charbroiler in the center, When lighting the charbroiler, the electronic igniter continues clicking up to 5 minutes after the charbroiler lights
Hi.
The igniters are all controlled by a main hub switch located under the cooktop panel.
Replace the sparking igniters module to fix the sticky igniters problem.
Regards.
Ginko.
Mar 03, 2010 | Stoves Ovens
Oven stopped working halfway through cooking. grill still works but top oven also stopped working
Sounds like to overheat device(s) kicked in. Is the background cooling fan still operating? i.e. that is the fan that continues to run for about 10 mins once everything on the device is switched off.
As well as hearing it, you should be able to feel a gentle draft of air coming out of the gap between the top and bottom doors.
Oct 04, 2009 | Stoves 720EF Electric Double Oven
Oven will not stay on .I believe it may be the timer
You have to ensure that the clock is set correctly with the time and it is in manual mode and nothing else is set on it.
Also that the background cooling fan has to be running as the oven overheat devices will kick in. This fan continues to run for about 10 mins, once the fan oven/top oven/grill is switched off. When it is running there should be a gentle draft of air coing out of the gap between the top and bottom oven doors.
Do you hear any relays operating when the fan oven turns off?
Sep 13, 2009 | Stoves 720EF Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
148 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
