Question about IBM Computers & Internet
My desktop hardrive (C) is running out of memory. I've attached an exterior hardrive (E) to the computer with lots of available memory. However, I'm still getting a message that I'm running out of available memory space on my hardrive (C). What am I doing wrong?
  • 639 Answers
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2)Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on Viwe Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you ee inside Temp Folder
5)Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you eill have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
If you feel that my answer has helped you in any way then please give a vote.
Thanks.
Posted on Apr 07, 2011
  • IBM Master
  • 32,281 Answers
The Windows operating system creates quite a lot of temporary files and this takes up hard drive space and eventually you run out of disk space.
This is why you need to do hard disk maintenance at least once a month to clean up your C drive and recover disk space.
For instruction on disk maintenance, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559146-hard_disk_maintenance
  • 1,719 Answers
C Drive is usually the partition of the hard drive that contains the Operating System. In your case, it might have been filled due the files stored on
1. Desktop
2. My Documents
3. Downloads etc
So, just move some of the data from your C Drive to E Drive and the issue would be resolved.
Hope it helps! Good Luck!
CreativeTECH
Dell xps 200 installed new hard drive
I share information HDD back site small jumper available so you attach 1-2 and CD back side available jumper not connect any pin. Mother board auto find it and not any issue ok.
Thanks.
TechSupportMart Computer Support
Feb 14, 2014 | Dell Dimension 3000 PC Desktop
My computer frequently stops responding, specially when i minimize windows. My screen usually leaves annoying images. I think it freezes that way. I've checked the device manager, my windows...
How much memory does your computer have? Alot of times when the temporary memory gets full everything will slow down and will cause applications to stop responding.
It can also be your hardrive is too full. The more space you use on your hardrive the slower it will go and if you fill it too full it will also make programs stop responding.
Sep 15, 2011 | Microsoft Windows XP Home Edition
Where do i insert a memory card from camera to transfer pix to desktop
If you have a builtin card reader else you can use usb cable or buy a card reader which is cheap about £1.
Jul 07, 2011 | Computers & Internet
Computer beeps three times and shows nothing on monitor.Nt able to start.
If your computer beeping..It means the Ram memory attached in the motherboard of your computer, Is not working
Try to remove and again install it. or you have to buy a new RAM and install
Hope this will solve your problem :)
Regards
May 05, 2011 | Computers & Internet
"low memory" message
Hello maxxoo,
There is a utility called Process Explorer on the Windows Sysinternals web site. It is very good at showing which processes are using a lot of memory. It may be helpful in determining what's causing the low memory problem. Process Explorer can be downloaded at this link:
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 10, 2010 | HP Pavilion a1610n PC Desktop
Optiplex GXS 240 Dell. After 6 years of hard work
Run the onboard diagnostics on the hardrives and system memory before doing the OS reinstall.
Instructions on how to run diagnostics are given below
http://tinyurl.com/lg7teo
Another workaround you can try is disconnect one hardrive from the computer and install the OS and then put the additional harddrive
Thanks for using Fixya
proton
Sep 18, 2009 | Dell OptiPlex GX260 PC Desktop
Operating system will not load
If all the diagnostics have passed. This means the problem is more or less a software conflict and that too a driver issue. Two things you can do.
1. remove all the memory sticks from the computer
2. Reinsert only one stick of memory, if you have only one try it in a different slot
3. Then power on the system
Kindly post back the results
Thanks
Proton
Jun 09, 2009 | Dell Dimension 4600 PC Desktop
My computer was shut down by power surge, i had to restore system to get it running again , more than once maybe 6 times!!!!! after that i defrag.... and there are now more files then were there originally...
you must backup your file and burn it in dvd/cd, any time your hardrive will be busted, the defrag is not god to use, wen your pc is not proper shutdown they can damage the hardrive,
backup your files and reformat your hardrive and install new O.s
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
