Question about Sharp AR-168D Copier
How do you unlock scanner lock knob, cant get it to turn?
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
How do you unlock the scanner? My printer has been off for a while. When I turned it back on it make this clacking noise and I got the message, "unlock the scanner." How do I do this?
open scanner until the red lever flops down. beside the lever on the left is a knob you squeeze and either pull or push depending on whether you are locking or unlocking it. Look through the glass screen and you'll it , there is a lock/unlock sign etched into the surface
Jun 03, 2010 | Lexmark X5150 All-In-One InkJet Printer
Sharp al-1655cs where is the scanner head locking switch?
On my Sharp AL-1551CS, it is located on the left end underneath the scanner unit.....it is a knob that rotates only 1/4 turn to either lock or unlock.
Feb 26, 2010 | Sharp SHP AL1655CS Printer, Scanner,...
Flashing L-1
When your copier scanner is locked.Then show L1
or sensor is dirty or scanner jam.
Solve: clean thoroughly then solve your problem.
Jan 22, 2010 | Sharp AL 1631 Copier
Scanner locked scx4521f
Turn the machine off. Look for a locking mechanism right above the area that copies exit out. There is usually a plastic knob that can be set to "lock' or "unlock". Rotate the knob to select "unlock" and this will release the scanner. You will have to look below the top frame and above the paper exit area.
Nov 08, 2009 | Samsung SCX-5115 Fax Machines
Wtf
hold down the light key/ lock key on the bottom left hand coner and it will unlock the unit
Jan 04, 2009 | Radio Shack Pro-82 Scanner
Cant find reset button inside scanner
There is a lock/light key at bottom left hand corner of buttons hold that down until it beeps and the buttons should be unlocked
Jul 27, 2008 | Radio Shack Pro-82 Scanner
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Toshiba printer e-studio 150
There is a small clear plastic circle under where the paper comes out, it has two positions, lock and unlock, sometimes when people grab the copies they bump it to lock, use a flash light and make sure its unlocked, you can also just remove it, it was there for shipping. L-codes = scanner lock problems, real cold conditions can cause the scanner greases to not allow the scanner to move fast enough, put the copier somewhere warm. Good Luck!!!
Jan 22, 2008 | Kyocera RI-3530 Black and White Copier
Scanner Locked
On the underside of the scanner assembly is a LOCK, it has two positions LOCK and UNLOCK. The manufacturer sets it to lock so the scanner doesn't move during shipment. You should be able to slide this to the unlock position.
Jun 12, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Sharp AR-168D Copier Logo
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
