Question about Dryers
I have a frigidaire elite model # de8800pwo that will run for about 3-4 minutes, then it stops and displays a flashin e-8. i have looked all over on line and either cant find the model ,or the error code. i have cleaned it out , but mabey not good enough? please help. it worked fine then we moved, and when i fired it up, well..... thanks. john
  • john lyons Apr 11, 2011
    hey tim . i am still having issues with the e-8 code after cleaning out all. and also now it is also showing an e-9 code. any ideas??? thanks, john
    President:
  • 3,074 Answers
E8= The safety (high limit) thermostat has tripped too many times within a certain period of program time.
Basically you have a restricted vent, solution clean vent. If I were you I would run a load of clothes with the vent tube disconnected, it shall dry. For some reason it does not fix the problem, reply and I will answer when I come home from work at 6 PM eastern time tonight. Good Luck Tim
Posted on Apr 07, 2011
    hey tim, i am still having issues with the e-8 code after cleaning out all. and also , it is now showing a new code of e-9 along with the e-8 code. any ideas? thanks, john
  • Tim Whalen Apr 12, 2011
    it sounds like your control panel board assembly is malfunctioning, you can order one from here:
    http://www.appliancepartspros.com/partse...
    here is eBay:
    http://shop.ebay.com/i.html?_nkw=frigida...
Won't stop running. This says I have to end with a ?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRC05L5DW1, is freezing the inside as well as running constantly. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. When power is restored, if you are still having the same issues, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire Refrigerators
Frigidaire FFB240 dishwasher won't stop
Good Morning AA1970,
I see that you are having trouble with your Frigidaire dishwasher, model# FFB240, continuing to run unless you shut it off. While I'm not familiar with this particular model number, I suggest that you give the appliance a hard reset. You will do this by shutting the power off at the circuit breaker for at least 20-30 minutes. After restoring power, run the cycle. If it is still continuing to run unless you shut it off, I suggest contacting a local authorized technician for further assistance.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire FFBD2406NS Built In Dishwashers
Frigidaire front loading washer, letter J in the display, will not operate.
First I recommend unplugging the washer for a couple of minutes then turning it back on. If that doesn't clear it unfortunately your are going to have to replace the control board. You can find the part here
http://www.repairclinic.com/ Just use your model number to look it up.
Oct 27, 2012 | Frigidaire Washing Machines
Kenmore elite refrigerator does not stop running
if cooling properly then nothing wrong with it. it defrosts every 8 to 12 hours. u probebly dont notice it
Oct 11, 2012 | Frigidaire FRT17G5CSB Top Freezer...
Won't run continuosly.
The first thing that I would look at is the compressor relay. The relay gives extra windings in the motor, power to get the compressor up to speed. It is a small thing that carrys a heavy load. (MORE)
Jul 07, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Elite HE3 - f2 blinking
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Kenmore Elite 45986 Front Load Washer
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Dryers Logo
Top Dryers Experts
