Question about Gateway FPD2275W LCD Monitor
Acer p221w monitor removing base
I have an Acer P221W monitor and I need to send it off for repair but I can't remember how to remove the base / stand. Can you help please?
If so, thank you. Tim.
Theres a black button at the back of the standard push it and then lift it up.
it is hard to push in but try
Sorin
Posted on Aug 13, 2008
  • Gateway Master
  • 5,568 Answers
Since you have surely looked, it isn't held on with exposed screws.
Check to make sure that the rounded area that allows tilting is not part of the case but appears to be separable.
Most that are removable are held by a tongue and a fairly obvious release tab.
if you can't remove the base, just place the monitor in the carton on good padding and upside down.
Fill and cushion the sides well, mark the carton with 'This side up' and an arrow and hope there are no malicious handlers on the trip.
I've shipped numerous monitors of different sizes and types and have lost none of them to shipping damage.
Posted on Aug 08, 2008
A vertical line in the middle of my Acer P221w monitor
dead pixels?? although im told dead pixels are red.
Feb 16, 2013 | Acer Computers & Internet
Picture changed to a blue dominant picture
disconnect the monitor from the system and check if all the pins of the cable are not damaged. if not damaged, then check the device manager for exclamation marks, try and reinstall the drivers
steps to open device manager;
click Start select Run type Devmgmt.msc press Enter
Apr 21, 2010 | Acer 22" X223w LCD Monitor
The desktop and applications are stretched
right mouse click on the desktop and select properties. Then go to the settings tabe and change the resolution. A picture of the screen shape on that window should give you an indication of whether or not you have chosen a compatible resolution
Jan 06, 2010 | Acer P221W LCD Monitor
I would like to know how to dim the light /screen on acer p221w monitor.It is very bright and i would like to know how to dim it
You should have some buttons on the front of the monitor, one of them is probrably a menue button which should allow you to adjust alot of the monitors settings from within there.
You can always download a manual by googling your monitors model number for exact instructions.
Nov 08, 2009 | Acer AL1916W 19" LCD Monitor
Screen resolution for Acer P221W
1680x1050.
It also depends on the video card how high the resolution can go.
That's the max resolution though.
Here's the complete specs for your monitor.
Have a good day!
Jul 18, 2009 | Acer AL1916W 19" LCD Monitor
ACER P221W No display and power light blinking
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If the monitor does not have any bad caps then I would be that when the video card died it sent a spike to the monitor and killed the driver board. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | Acer P221W LCD Monitor
Monitor Problems
It has a 3 year warranty.
Mar 15, 2009 | Acer P221W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
549 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
