Question about Rancilio Silvia Espresso Machine
Water not heating. Red light stays on. - Rancilio Silvia Espresso Machine
  • 1,089 Answers
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Posted on Apr 08, 2011
How do I start a 1973 komfort travel trailer water heater?
See if big red knob has a PILOT or LIGHT setting and put it on that setting. Next look at knob on bottom-- it should have a circle cutout on it that needs to align with the pilot push button. The cutout lets the button be pushed in. While holding button in---light the pilot and keep holding the button in for about 3 minutes. If everything is working right with the water heater, after 3 minutes or so you can let go of the button and the pilot should remain on. If it stays on. turn the smaller button to the run or heat position and the big burner should come on. Then set the big heat control knob for the heat setting you want.
May 20, 2015 | Water Water Heaters
HUMIDASTAT INTERNAL RED LIGHT USED TO BE ON AND UNIT WORKED. LIGHT STAYS OFF AND UNIT DOES NOT WORK. WHEN I DISCONNECT AND REATTACH HUMIDISTAT POWER LINES, RED POWER LIGHT GOES ON FOR A SECOND AS DOES THE...
will not blew very good heat and shut down with stop light came on it dose work for 30min after i drain the water but it go back to the stop light again then the will for about1min or so then it shut again
Nov 04, 2013 | Aprilaire 4655 Manual Humidifier...
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
I turn on the power switch and the blower turns on and stays on. I can get the pilot light to stay on but the burners will not light even after I turn the RED gas valve to ON. There is no thermostat...
Hello Skyhalliday,
I understand that you are having a problem with you central heat/air. You do not have a thermostat installed and have the red and yellow crossed in order to make the unit run.
The wires you have crossed are not to the heat if they are to the common color code. Here is the color code for HVAC units:
Thermostat / Wire / what is controlled
W / White / Heat gas valve or heat elements
Rc(Rh) / Red / 24 volts transformer
G / Green / Fan
Y / Yellow / Air Conditioner Outside unit
C / Blue or Black / Common (energizes thermostats that do not have batteries)
You may not have the proper wires shorted in order to have the burners engage.
Thank you for choosing FixYa.com
Justin
Apr 04, 2011 | Heating & Cooling
Changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
After descaling the two coffe cup lights keep flashing .
Hi
You have finished the descale process and your descale light should be gone. Put a fresh tank of water on the machine and then open the steam knob. This should clear the water light and your machine will start heating again.
May 24, 2009 | Starbucks Saeco Italia Digital Barista...
My car over heats and only blows cold air through the heater
Sounds like your thermostat is stuck or bad. Replace thermostat.
Jan 31, 2009 | 1991 Volkswagen Passat
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Rancilio Silvia Espresso Machine Logo
189 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
