The laptop would not turn itself off after closing down. Advised it was a network issue and that I should reload from scratch. This I did and now find that there are a number of drivers missing. Ethernet controller, network controller, fingerprint sensor, PCI Simple Comms Controller. The laptop is a Toshiba Tecra A11-1EG using Windows 7 OS 32 bit
  • 639 Answers
Just perform the following steps and i am sure your issue will be resolved.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the last month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Please leave a vote if you like my answer
Posted on Apr 07, 2011
How can change Vostro 3300 32bit- 64bit
You'll have to reload from scratch (not upgrade) a 64-bit operating system, such as Windows 7. Make sure the reason you think you need 64 bits is worth the time and effort of:
1. Saving ALL your Data Files before you start, perhaps to an external HDD, a USB flash drive or a network drive.
2. Saving backups of all your applications -- electronic banking, Email, Address books, etc. (Outlook data files)
3. Reformatting and reloading a new OS (you'll probably have to buy it).
4. Reloading all your applications (make sure you have ************, serial numbers, etc.
Unless you have a new mission-critical app that requires a 64-bit OS, I'm not sure you'll be happy with the outcome. The PC probably won't perform any better than it does now.
Apr 02, 2017 | Computers & Internet
Laptop worked fine then shut it down turned it on again & TOSH screen appeared but then screen went black and a blue box came on saying Enter Current P'word. when i did that the laptop turned off.
Last time you used the computer you did something wrong. Of course, computer said nothing but it reared its ugly head when you restarted it! Computers are treacherous - they bite you when you least expect it - women are more predictable.
See if you can boot up by hitting the F8 key and selecting " last setup that worked" option. Do you have restore disks? If so use them to go back and possibly repair the OS. Also check with Toshiba for any other options. If nothing you just might have to reload the unit from scratch using the restore disks. If you never made them as advised then you are really scr--d. Either you buy the disks from Toshiba or you borrow some friends)S disks and do the deed.
Sep 26, 2015 | Toshiba Satellite L305-S5933 Notebook
Dell Inspiron going to hibernate when its not set on hibernate
The hibernate mode is one of microsoft's worst idea because it often corruped window files forcing the user to reload windows from scratch. When you were in power options did you also turn off standby? and set it to never on the list.
Apr 27, 2012 | Dell Inspiron 15R Laptop
How do i get rid of the thin blue line down my laptop screen?
This sounds like you have a fracture in your LCD. Unfortunately it sounds like you will need to replace the screen which can be done but it's not advised as it is rarely cost effective based on the laptop age and model.
Mar 01, 2011 | Computers & Internet
I've spoken to who provides my wireless network and they insist that my Dell laptop is the problem for not being able to connect. I really dont know much about what they were saying but what they had...
If your using a router to get wireless from a DSL connection and your laptop isn't detecting the signal it is most commonly the wireless card in the computer, hence their response. If you can access the router to check what channel it is transmitting on you may be able to change that to resolve the issue. On my cisco router it transmitted on channel 6 by default and my laptops wouldn't detect it, I changed it to transmit on channel 5 and the laptops work fine. I assume they checked if your router was compatible with your computer so I won't go into the type G wireless vs Type B or N wireless. The uninstall/install process they recommended is not hard and shouldn't hurt anything if you do that. On Vista Open Control Panel->System->Device Manager then go down the list of devices to Network Devices and select your wireless adapter and right click, from that drop menu select uninstall and close everything and reboot the computer. When the computer starts up again it will automatically detect the wireless card and reinstall the drivers from the windows system copy. Make sure the wireless device is actually manually turned on before doing any of these steps. Once the device is installed again you should be able to detect the wireless signal from the router they supplied. If not there is one more place to look in the router itself unless you are familiar with router settings I don't recommend you do these though. If you still don't detect the router signal call your supplier back and have them go through the router connections with you and when they say it's your computer you can tell them it works fine with others and you removed and installed the device as they advised and the fault is in their router.
Sep 08, 2010 | Dell (430-3572) Wireless Adapter
I have a hp compaq nx7300 laptop. when I boot up
See if it will run a bit longer in safemode tap F8 as it boots - then choose "safemode with networking" - see if that works If it does - then try doing a clean boot - details here http://support.microsoft.com/kb/331796
Now if it works when booted normally - you will need to go back into the configuration tool and find out which program is causing the issue - reply here if that's the case, and I can work you through the detail
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | HP Compaq nx7300 Notebook
Toshiba Laptop turns itself back on after being shut down
go to toshiba's website
www.toshiba.com select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Ruben
Jul 18, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
