The printer pixma ip90 does not work, because when it is switched on, it gets jammed, while it is preparing to print.
    Guru:
  • 370 Answers
Welcome to FixYa.
Paper may get stuck or jammed in the printer. Follow instruction below to find and remove jammed paper.
1. Turn off the printer.
2. Unplugged the cable of printer from the computer.
3. Remove all loose paper from the paper tray.
4. Do not pull jammed paper from under the front cover.
5. Press the resume button, If the paper is still jammed maybe there is still some scrap of paper, proceed to the next step.
6. Remove the back door or rear access door.
7. Pull the jammed paper out of the printer.
8. Check to make sure no scraps of paper are stuck in the printer.
9. Put the rear access door back into the printer.
10. Plug the cable printer to the computer.
11. Turn on the printer.
Hope this information will help.
Thank for using FixYa.
Posted on Apr 07, 2011
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Dec 26, 2013 | Canon PIXMA iP90 Mobile Printer
My printer is jamming on the right side only..help
While Jamming the Cartage in your Printer, as which ever side as it's.
Make the few steps to over come the Jamming Problem.
1. Switch on your Computer and Printer,
2. Go to the My Computer ->Control Panel in your Computer,
3. Click Printer Setting Icon.
(There you can view your Printer as Cannon PIXMA iP90)
4. Right Click on the Icon.
5. Go to its Properties
6. There you can find "PRINT TEST PAGE"
7. Click and wait to your printer to print its test page.
8. Open the Top Cover of the Printer,
9. Check cartridge, See where its Jam, also in its Moving Position
While Jamming the cartridge Slightly push to its direction of running.
10. After Completing its printing, Check the Botton Plate, which you can see at the bottom of
the cartridge, The Plate some time gets in slight Bend to the running actiono fht ecartridge
11. If the Plate gets stuck to the cartridge, adjust the plate.
12. Take an Soft Cloth and wipe the Cartridge rod, where you can find the dust particles in the
cloth after wiping the rod.
Try to keet the Printer close, and keep away from the Dust Particles, Better Cover the Printer using the Cover or Good Looking Cloth when not in USE.
Jan 03, 2011 | Canon PIXMA iP90 Mobile Printer
Paper will not start feed in on it own
Probably no paper jam, but put a ruler across the top across where the switches are, if it's bowed down some the frame has been bent. Any weight, luggage,etc placed on top can bend the frame and that restricts the paper path and you need a shop repair.
Jan 08, 2010 | Canon PIXMA iP90 Mobile Printer
IP90 Canon Printer shows error code 5100: How do I fix it?
This means there is something jamming the mechanism. You should take it to a repair specialist or do your best to check for blockages yourself. It can be the tinest little thing. Check everywhere!
Sep 01, 2009 | Canon PIXMA iP90 Mobile Printer
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
My Canon Pixma IP90 will not print. It pushes the paper
you going to take printer in for repair.or get a new one
Jul 18, 2009 | Canon PIXMA iP90 InkJet Printer
Cartridges seem to be getting jammed
Check the frame is not bent down in the centre (often caused by dropping)
Dec 26, 2007 | Canon PIXMA iP90 Mobile Printer
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
54 people viewed this question
jasbo
jasbo
