Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Hi i've got the cover off my maxi cosi car seat to clean it but now can't remember how the bottom strap goes back properly. pls help.
  • Maxi-Cosi Master
  • 1,629 Answers
Hi - We anticipate that you are struggling to get the tensioner strap back into that H shaped piece of plastic - it is very fiddly to do, and you may find it easier to do with the flat handle of a spoon. If you're not sure its done properly take your carseat to an authorised Maxi Cosi retailer and ask them to check it for you.
Posted on Nov 29, 2011
Put cover back
Hi
Please contact Dorel USA for assistance with your enquiry
Jan 09, 2014 | Maxi-Cosi Mico Infant Car Seat
Put cover back
Hi Eric
Please contact the Maxi-Cosi customer care team in USA & Canada for assistance -
Have maxi cosi infant car seat (new born to 9 months) took straps out of back to give them a scrub and it's still attached to bottom of seat but i cannot remember how to put the straps back up through...
Good Afternoon
Due to the safety implications of the harness being incorrectly put back, the carseat would need to come back for the engineers to replace it. Please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss booking it in.
Sep 11, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi, i cannot get my maxi cosi to recline. can you offer any help with ideas?
Hi Lorna - Most commonly this issue is caused by dirt/debris getting caught in the tensioning strap of the harness and gradually pulled into the mechanism of the carseat over time. First recommendation is to remove carseat from the car and remove cover (do not remove harness system from seat) give the carseat fabric and the seat itself a clean and see whether this improves the recline situation. If not, please contact your customer services department - if you're in the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Aug 11, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
Changing the maxi cosi car seat cover : how do you get the buckles through the adjustment strap opening they do not fit have i done something wrong?
Hi, Yes the **** strap will fit through the hole, although this is a tight squeeze, but often something that people mention as a little tricky. I hope this helps.
Jun 11, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi Cosi Prior XP Car Seat
If you contact www.maxi-cosi.com you will be able to order these parts or be put in touch with a more local company.
I hope this helps.
Jan 13, 2009 | Maxi-Cosi Priori
Maxi-cosi priori previous model
There is a brackety thingy (sorry I'm not real technical) in the back that the straps connect to. Remove them, extend it, and re-connect them.
Jan 20, 2008 | Maxi-Cosi Priori
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
74 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
