Question about Brother MFC 6490CW InkJet Printer
Dcp 6690cw error code init.50 - Brother MFC 6490CW InkJet Printer
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
Brother dcp-6690cw a3 scanner replacement glass
Probably best to go the Brother Support at
http://www.brother.co.uk/g3.cfm/s_page/204620/s_name/askaquestion2
Maybe you could go to a glass seller and have a replacement cut to match?
Mar 10, 2014 | Brother DCP6690CWU1 DCP-6690CW Colour A3...
Printer Brother DCP-6690cw unable to print 50, sometimes unable to clean 50. please help
A 50 error code indicates a problem with the "maintenance unit".
This unit controls and cleans the printhead and ink delivery system. You will need a technician to figure out if this is the problem or some other component has failed.
Sep 03, 2013 | Brother Office Equipment & Supplies
How to reste counter cartridge on brother dcp 6690cw
replace the cartridge, machine see the cartridge as new, reset machine thinks its new when in reality its old causes code and image issues
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 28, 2013 | Brother Ink for Dcp-6690cw and Lc-1100
Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Jun 12, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
Brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Nov 21, 2010 | Brother DCP 165C Compact Color Inkjet...
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Brother MFC 6490CW InkJet Printer Logo
876 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
