Question about Mavic Ksyrium Elite Wheelset
Ik heb een ksyrium elite wielset 2011. De naaf va het voorwiel loopt aan wat een schurend geluid geeft. Het probleem zit in de kapjes waar de schuursporen zichtbaar zijn als je de as losmaakt. Is een al erkent probleem? en komt mavic met nieuwe kapjes? bedankt, bjorn
5 Suggested Answers
  • 86 Answers
SOURCE: Can you replace the rear Campagnolo 8 speed
yes
Posted on Feb 06, 2010
  • 18 Answers
SOURCE: cant put my mavic back together properly
It sounds like you lost the washer that sits between the bearing in the nose and the freehub bearing. If you lose that washer, when you re-tighten the axle, the two bearings will bind and prevent the freewheel from spinning easily.
Take your freehub off again and see if that washer is there. If it isn't, you'll have to get a new one and replace it. It's easy to lose that thing if you don't know it's there when you take the wheel apart, because it'll just fall out.
When I reassemble those wheels. I thread the drive-side axle through the freehub body, then place the washer over the axle on the inside of the bearing, then thread the axle through the nose.
Also note that if your freehub seemed loose, it probably needs to be replaced. The FTS-L freehub body used on the Ksyrium wheels uses a nylon bushing as the friction interface to the nose, and this bushing wears down over time even with good lubrication.
Posted on Mar 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: Ksyrium Elite Wheelset: Raced this morning on mavic axioms and the hubs we...
Bearings. Take it to the Bike Shop.
Posted on May 05, 2010
  • 25 Answers
SOURCE: Wheel does not stay true
Check if your spoke are tight enought, sometimes if the spokes are loosen the wheels will bent really easy.
Posted on May 18, 2010
Wat kan de oorzaak wezen dat het zo moeilijk schakelen is bij mijn motorfiets en tevens zeer moeilijk ook hem in zijn neutraal te krijgen?
Hallo, Aprilia46, wat is jouw vraag? Ik begrijp niet wat je probeert te zeggen. Ik heb meer details nodig over wat er aan de hand is, probeer je probleem uit te drukken in de vorm van wat je probleem bevat, dat een of meer van de volgende woorden bevat: Wie wat wanneer waar waarom Voltooi uw zin met een vraagteken in plaats van een periode. Als Engels niet uw primaire taal is, schrijf dan de vraag in uw moedertaal. Ik zal vertalen en reageren in hetzelfde. Ten slotte, zorg ervoor dat u het jaar-make-model van uw motorfiets of scooter omvat. Klik alstublieft op het 'commentaar' woord hieronder en geef deze informatie in het vakje zonder limiet op woorden. Nadat u het bericht hebt geplaatst, verschijnt er een reactiewaarschuwingspictogram op mijn scherm waarmee ik kan reageren op uw oorspronkelijke vraag in een ander commentaarvak Onder de jouwe. Veel geluk en een geweldige dag.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 17, 2017 | 2007 Aprilia RS 125
Mijn vraag is ik heb een Philips CDR 560 cd recorder alles werkt maar de VU meter geeft geen geluid signaal aan en er komt ook geen geluid uit de cd recorder als ik een cd wil afspelen terwijl de...
typically english is the prefered language to seek assistance. By submitting your query in non-english, you have reduced the potential for help by 800%
Oct 26, 2014 | Office Equipment & Supplies
Fuji HS 50
Ja dat is een flauwe grap van de camera fabrikant. Ze leveren nooit een geheugenkaart bij een camera. Soms doet een winkel er een kaart bij, maar daar heb je vaak niet veel aan. De kaarten in de winkel zijn ook altijd veel te duur, omdat de foto winkel of mediamarkt veel te veel van die dingen op voorraad heeft. Ze proberen met de kaarten iets meer winst te maken dan met een camera.
Het interne geheugen van een camera is meestal niet groot genoeg, om er meer dan een of twee foto's in te zetten, van de hoogste kwaliteit.
Als ik je een advies mag geven, koop een of twee kaarten via het internet. Kijk bij tweakers.net onder pricewatch, waar je de SD kaart van jouw keuze besteld.
Als je van plan bent heel veel te gaan schieten, kun je op een 64GB kaart duizenden jpg foto's opslaan. Maar een of twee 16 GB kaarten kun je ook ontzettend veel mee. Kies wel een Class 10 of een U1, omdat die bij het wegschrijven vanuit het buffer, de camera sneller maken. (Sport fotografie is video op hoge kwaliteit)
Succes
Feb 20, 2014 | Fuji FinePix Cameras
Heb foutcode 800488fe,kom niet meer in mijn account hoe los ik dit op?
Vermoedelijke Reden
U ontvangt deze fout Omdat De anomalie?n in uw Windows werden gevonden Leef rekening.
Achterhaal het probleem
Vergewis u eerst ervan Dat niemand anders uw rekening gebruikt, Wanneer u te vele e-mails Binnen 24 uren stuurt of zijn vele commentaar op Verschillende blogs of profielen op Windows Leven, in de meeste Gevallen, Microsoft kan interpreteren dit verlaten zoals spam mei Activiteiten en bijgevolg uw rekening Tijdelijk belemmer.
Te bevestigen dat uw rekening hier gaat en volgt de op het witte doek Instructies om het controleproces te vervolledigen. In Sommige gevallen Kan het Worden Gevraagd een mobiel nummer binnengaan, indien niet u deze procedure kunt gebruiken te bevestigen dat de rekening of u niet kunt doen zo door het Contacteren van het Windows steun door het gaan hier Leef, een moderator zal aan uw beschikking zijn en die u zult helpen eigenaarschap van het Windows Terug te winnen Leef.
https://login.live.com/login.srf?wa=wsignin1.0&rpsnv=11&ct=1298742766&rver=6.1.6206.0&wp=SAPI&wreply=https:%2F%2Faccount.live.com%2F&lc=1033&id=38936
Indien ik van verdere hulp zou kunnen zijn, verhuur mij weet. Indien dit helpt of lost de kwestie op, schat alstublieft het en geeft een testimonium voor mijn reactie Bedankt, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 26, 2011 | Computers & Internet
Een dikke zwarte streep op de achterkant van het papier, bij eerste afdruk na opstarten van printer
Mijn 4 jaar oude Canon MP500 begon ook een brede zwarte streep te trekken aan de onderkant van het papier. Dat gebeurde na iedere reiniging van de koppen, de eerste paar velletjes kregen een zwarte streep en daarna was het meestal goed totdat de printer zijn koppen weer reinigde.
Bij het reinigen van de koppen wordt met een soort pompje wat inkt door de kop gezogen. Deze inkt wordt via een slangetje afgevoerd naar de ruimte tussen de bovenste plaat en de bodemplaat van de printer. Een groot deel van de bodem van de printer is gevuld met een soort vilt dat de inkt kan opnemen. Zolang het vilt inkt opneemt is er niets aan de hand, maar bij mij was het vilt rondom de uitstroomopening van het slangetje helemaal verzadigd met ingedroogde inkt. Daardoor kon nieuw aangevoerde inkt alleen maar omhoog tot aan een aandrukrol voor het papier. Dit aandrukrolletje bracht de inkt keurig over op de onderkant van het papier.
De oplossing is de printer uitelkaar halen en de overtollige inkt in het binnenste verwijderen. Dat is een vies werkje waar je echt even voor moet gaan zitten, en als je niet handig bent kun je er beter niet aan beginnen.
Trek alle kabels (vooral de 230V) uit de printer en zet hem op een goed toegankelijke plek waar je een dikke laag kranten op hebt uitgespreid. Eerst verwijder je de zijkanten door 2x2 schroeven los te draaien. Het lipje aan de voorkant moet je vervolgens (een beetje) naar voren trekken zodat het los komt. Aan de achterkant is een schroevendraaier in de naad handig, de zijkant komt dan los en kan naar beneden toe worden verwijderd.
De veer van de scanunit krijg je los door aan de voorkant twee lipjes opzij te buigen. De scanunit is nu vrij, maar is nog verbonden met de printer met 3 massadraden, een connector met 4 draden en twee flatcables. Die moet je met moed en beleid loshalen, en noteer even wat waar zit. De draden loshalen is geen probleem, met de flatcables moet je heel voorzichtig zijn, zo dicht mogelijk bij het connectortje vastpakken (daar is de flatcable iets dikker) en voorzichtig er uit trekken.
Nu kun je de kap loshalen (4 schroeven).
Dan kan het printermechaniek worden verwijderd van de bodemplaat door 4 schroefjes te verwijderen. Om bij de vierde te komen moet je de voeding loshalen: een connectortje bovenop losmaken en aan de onderkant twee lipjes opzij buigen. De voeding komt dan naar onderen uit de printer.
Maak alles enigszins schoon, verwijder in ieder geval alle dikke lagen inkt. Dan weer alles in elkaar zetten. Als je geen magnetische schroevendraaier hebt, kun je ook tijdelijk een dun draadje om de schroefjes wikkelen om ze op de goede plek te krijgen. Denk er aan om de schroefjes die in kunststof worden gedraaid, eerst even de verkeerde kant op te draaien. Je voelt dan een klein klikje waardoor je er zeker van bent dat de schroef precies in de oude draad komt. Doe je dat niet, dan heb je een grote kans dat je het schroefje dol draait. De flatcables hebben maar aan een zijde contactjes, dus steek ze juist om in het connectortje.
Als alles weer in elkaar zit doe je een schietgebedje , sluit de printer aan en testen maar...
Feb 07, 2011 | Canon Pixma MP500 All-In-One InkJet...
Waste ink near full
I'm having the same problem. Lots of solution for resetting the printer, but none of them helping me to lead me to the absorber itself inside the printer. It seems to be a lot of work and disassembling half of the printer! Looking on internet I haven't found any answer yet.
As I am living in The Nehterlands I'm looking for solutions in Dutch. One solutions discribes disassembling another Canon printer. This could possibly help. I'll paste the text below. It's dutch, so you'll have to translate it.
Wishing you succes with this matter!
Dutch text:
Wat te doen bij de melding 'Afvalinkt bijna vol'?
Onderstaand verhaal geldt voor de Canon SmartBase MPC200; voor andere Canon
printers geldt ongeveer hetzelfde, met uitzondering van de reset-procedure (zie
hieronder).
Oorzaak
Onderin de printer bevindt zich een langwerpig, dik vloeiblad (een soort spons van
vilt). De overtollige inkt, bijv. de inkt die gebruikt wordt bij het reinigen van de
koppen, wordt afgevoerd naar deze spons. Als deze spons bijna verzadigd is,
verschijnt bovenstaande melding. Dat is ook nodig, want als je gewoon door zou
kunnen gaan, zou de spons geen inkt meer opnemen, en op een bepaald moment zou
je merken, dat de printer zou gaan 'lekken'. Geloof me, dat wil je niet meemaken.
Printerinkt is gemeen spul!
Canon
Het lastige is alleen, dat Canon nogal moeilijk doet over deze melding. Zij hebben
maar één oplossing: opsturen en het probleem door hen laten verhelpen. Kosten: ruim
€ 100,-!!! Toen ik dat van de telefonische helpdesk hoorde, reageerde ik met: "Dan
kan ik beter een nieuwe printer kopen!" De telefoniste was dat eigenlijk wel met mee
eens.
Zoeken
Vervolgens ben ik gaan zoeken op het internet. Wat je daar niet kunt vinden, bestaat
niet, tenslotte... Toen merkte ik al snel dat ik niet de enige was met dit probleem.
Iedere eigenaar van een Canon-printer krijgt er na verloop van tijd mee te maken.
Helaas was er geen kant-en-klare oplossing voor mijn printer, maar door de
beschrijving bij andere printers kreeg ik wel een idee over de oorzaak van het
probleem en wat ik eraan zou kunnen doen.
Oplossing
Over de oorzaak heb ik al geschreven. Over de oplossing gaat het nu. Die gaat in twee
stappen:
1. De vilten spons schoonmaken.
2. De printer resetten.
Dit is een vies werkje. Doe een schort om en gebruik huishoudhandschoenen! Inkt in
je kleren gaat er niet meer uit en op je handen duurt het een hele tijd!
De spons ligt helemaal op de bodemplaat onderin de printer. Je moet dus een beetje
handigheid hebben en niet bang zijn om een schroevendraaier te gebruiken.
Schroef eerst de beide zijkanten van de printer los. Die zitten elk met twee schroeven
vast (één aan de voorkant en één aan de achterkant).
Verwijder dan het toppaneel (met de scanplaat). Die zit vast met twee schroeven aan
de achterkant en drie aan de voorkant (deze drie zitten aan de onderkant van het
bedieningspaneel). Let op: zodra je het toppaneel verwijdert, merk je dat die op drie
plekken vastzit. Op één plek met een schroef (gewoon losdraaien) en op twee plekken
aan de elektronica. Trek die twee punten voorzichtig los. Je kunt het toppaneel nu
opzij leggen.
Dan moet je de printplaat verwijderen. Maak eerst alle 'draden' voorzichtig los. Kijk
goed hoe het vast zat, om het later weer te kunnen bevestigen. Maak dan de printplaat
los (4 schroeven). Verwijder daarna ook de metalen plaat, waarop de printplaat vast
zat.
Je bent er nu bijna. Het bovenste deel van de kast (voor zover die er nu nog staat) is
op de vier hoeken met schroeven bevestigd op het onderste deel van de kast. Je moet
misschien wel even zoeken, want ze zitten diep weggezakt. Schroef ze los.
De bovenkant en de onderkant zijn nu los van elkaar, maar nog wel met draden en
elektronica aan elkaar verbonden. Maak die verbinding niet los, dat is niet nodig.
Doe nu het schort om en de handschoenen aan!!
Je kunt nu bij de bodem van de kast komen. Daar zie je de spons, die zwart is van de
afvalinkt. Kijk eerst hoe de spons erin zit, voordat je die eruit haalt.
Maak de spons voorzichtig schoon. Niet wringen en zo, alleen uitspoelen en eventueel
induwen om de inkt en het water eruit te halen. Ga een flinke poos door, totdat er
alleen nog schoon water uit de spons komt.
Hang de spons een paar uur te drogen in de zon. Gebruik daarna een föhn om ook het
laatste beetje vocht eruit te halen, zodat de spons weer kurkdroog op zijn plek gelegd
kan worden.
Zet de zaak nu weer in elkaar. (Als je het net zo doet als ik, houd je twee schroefjes
over, maar mijn printer doet het nog steeds prima. )
1a. Niet schoonmaken maar bestellen...
Sinds kort weet ik dat je de spons ook kunt bestellen. Dat scheelt een boel pruts- en
schoonmaakwerk.
Je kunt de vilten spons, die uit 2 onderdelen bestaat, bestellen bij ETB (Electronic
Trading Benelux).
Bel naar 0165-850500 en bestel de volgende artikelen:
HC1-0795-000
QA4-0213-000
Toen ik ze bestelde (in maart 2006) waren de kosten voor deze 2 onderdelen samen
maar E 1,04!!
Deze prijs was wel exclusief btw en verzendkosten. Maar omdat ik het samen met
andere producten bestelde, had ik daar geen last van.
Als je nu de printer weer aanzet, kun je merken hoe dom het apparaat is. Hij heeft niet
in de gaten dat de spons weer schoon en leeg is. Dat moet hem nog verteld worden.
Op het internet kon ik daar geen geschikte procedure voor vinden, dus ben ik maar zo
brutaal geweest om Canon op te bellen. Eerst deden ze afwerend (ik moest de printer
opsturen), maar toen ik vertelde, dat ik het grootste deel van het werk zelf al gedaan
had, kreeg ik een technicus aan de lijn, die me stapsgewijs uitlegde wat ik moest doen.
De stappen laat ik hieronder volgen:
1. Zet de printer aan
2. Druk op de (langwerpige) menuknop
3. Druk op de meest linkse ronde knop (Copy)
4. Druk op de ronde knop rechts daarvan (Scan)
5. Druk twee keer op de meest linkse ronde knop (Copy)
6. Druk op het min-symbool (links van OK); het scherm zegt nu: 'Test mode'
7. Druk op OK
8. Blader met het plus-symbool (rechts van OK) tot het scherm zegt: '#8 Printer
Test'.
9. Druk op OK
10. In het scherm staat nu: '8: Printer Test' en daaronder: '- 8 - 2 +'
11. Druk 1x op het plus-symbool; in het scherm staat dan: '- 8 - 3 +'
12. Druk op OK
13. In het scherm staat nu: '[0]: Ink Count'
14. Druk op OK
15. Druk op de knipperende oranje knop om die uit te laten gaan.
16. Mogelijk werkt dat niet. Trek dan de stekker uit het stopcontact.
17. Wacht even. Doe de printer weer aan.
18. Als het goed is, ben je nu bevrijd van de irritante melding over afvalinkt.
Succes!!
Nov 04, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Lens van mijn Ricoh Caplio R 6 gaat niet meer in of uit
Hoi Van de caplio R6 zijn geen onderdelen leverbaar, de camer moet worden aangeboden aan Ricoh Nederland ze zullen je een website aangeven waar je de gegevens kunt opzetten en daarna pas de camera kan opsturen aan hun servicecenter
Groet,
Rob Rotronica
Apr 15, 2009 | Ricoh Caplio R6 Digital Camera
Garmin nuvi 350
Heb je het al eens op een andere pc geprobeerd. Het kan zijn dat je usb stack (software) van je windows installatie stuk is. Probeer eerst eens een andere pc, werkt het daar wel, dan weten we een beetje waar het probleem zit.
Jul 23, 2008 | GPS
Machine wil niet starten
I understand your problem but need the make and Model # to help you with the programming problem
Apr 07, 2008 | Washing Machines
Mavic Ksyrium Elite Wheelset Logo
141 people viewed this question
Top Mavic Cycling Experts
Michial Gueffroy
vidiot1961
Level 1 Expert
Paul Bade
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
