Question about Magic Chef CGR3725 Gas Kitchen Range
Magic Chef gas range
My propane ran out. I refilled it. I tried to turn the burners on. They all lit. I turned them all off. The ignitors continued to fire at all of the burners. I believe the oven ignitor was also firing. Can you tell me if I need to replace the spark module and if so how would i go about finding it.
  • JFVolpe Aug 06, 2008
    I don't have a manual for this model. It was in the home when I purchased it. I believe it was made in 1997 - 1998.
  • 770 Answers
Please check and make sure the knobs are not stuck in pull on each of them the oven does not spark it has a glow bar but there are switches behind the knobs that maybe sticking check that first
Posted on Aug 06, 2008
Ignitor is lit but oven doesn't fire top works fine, but no gas in the oven.
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 20, 2010 | Magic Chef CGS1740 Gas Kitchen Range
Oven wont work but range top does
Your range has a small 3"x1"x1" metal box with a gas valve going into it placed right behind the broiler flame tube; this gas safety valve alows the gas to enter the "pilot" tube to be lit by an piezio electric ignitor: that is the clicking you hear when you try to operate the oven. this gas valve needs to be replaced as, it is not opening to feed gas to the ignitor. an appliance parts store will have the oven gas valve; it just screws into place. be sure to turn off the gas and, remove power to the range before you do any work on it.
Apr 06, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef gas range ignitor continually clicking
One of the burner control switches is shorted. If they are not overly expensive I replace all 4 while it is apart.
Eric
Feb 23, 2010 | Kitchen Ranges
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Leak Safety Valve Magic Chef Oven?
that could be rigth only if that ignitor is good,,,that ignitor has to glow bright orange,,if its weak,,which it sounds like to me,,the gas will take a long time to ignitor,,or dont ignite and you smell a wee bit of gas,,,onthejob
Jan 08, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef propane oven. recreation vehicle application
you need to check the amp draw on the ignitor.. if it is between 3.5 -5.2 amps your gas valve is bad..if not the ignitor is bad..YES theignitor can glow and still be bad due to lack of amp draw to open the valve..check that and let me know
Feb 22, 2008 | Kitchen Ranges
Magic Chef CGR3725 Gas Kitchen Range Logo
133 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
