Question about Sony Televison & Video
I have a Bravia TV and have lost Channel 7 - Sony Televison & Video
  • Sony Master
  • 8,457 Answers
Ur tv is hook up to a antena and getting free AIR DTV broadcasting signal?Yes,tv have lost channel 7 tunning in frequencies.Go into ur tv menu goto SETUP and pick EZ or Wizard scannning might get it back,not must go into Ch. pick AIR not Cable to rescan the whole thing for picking up all free AIR DTV channels again.If tv it is getting pay Cable do the same thing,pick CABLE for channels scanning not AIR.
Posted on Apr 07, 2011
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Had a Sony Bravia 32"
sounds like maybe the tv cable going to the tv if not that then i would suspect that the tuner in the tv is going bad
Jan 23, 2011 | Televison & Video
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
GUIDE LISTING QUIT WORKING ON BRAVIA TV
try go sony web
http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL52W4100&LOC=3
Download up deta
Download Tips (Includes how to download multiple files at once)
Feb 16, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have lost channel 7, 9, and 10. how come that happened?
Hi my name is Roety,
I can help you with your issue ,
Possibilities are that you pressed the ANT button putting the TV in tuner b mode. or pressed the video input button.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 22, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
226 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
