Question about Sony DAV-HDX500 System
Thow do i get my sony dvd surround system to play it says push power protecter but i cant find it on the remote
  • 416 Answers
Power protector should be a button near the rear where the AC cord connects through the casing
Posted on Apr 07, 2011
  • tkurariki Apr 07, 2011
    im sorry an were or what is the ac cord that connects through the casing im trying to look for it but i see no button
  • Remote Computer Rescue
    unplug everything and power up just the unit.......if it works while standing alone with no speakers or anything else plugged into it, then you must make sure you are using the specified 3ohms speakers and 1.5ohms sub, also that there aren't any bare speaker wires touching each other or the system case itself. Finaly, the unit needs to have at least 2-3 inch clearance from the vent holes.
    GOOD LUCK and if problem persists your unit will need professional "hands-on" attention
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
Does this model have Bravia sync?
Yes it does per SONY web site:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665164630&langId=-1#specifications
BRAVIA® Theatre Sync™ technology
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
Feb 02, 2011 | Sony BRAVIA KDL-40V3000 Television
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Feb 25, 2009 | Sony DAV-S400 System
Need Dish Network Code for Sony DAVHDX275 Audio System
Refer to page 82 in your Dish Network User's Guide......(Make sure Sony system is powered on and in DVD mode with a disc in the player).  Point Dish remote at Sony box -  Hold Aux until all buttons light up at top....press 2 - then STAR button* and then POWER button - then press the up arrow key repeatedly until Sony turns off - press # key to lock in code.
It took me awhile to get it to work....it will only work power, mute, and volume - not dvd play functions. Refer to page 85 to make the Dish remote control the Sony box volume by default.
Good luck.
Jan 25, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
Sony DAV-HDX500 System Logo
303 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
